Server Unavailable
scott
scott posted this 5 days ago
I am unable to connect using Themler Desktop. I get this msg: Server Unavailable. I have ensured all proxy, firewalls and anti virus. Still cannot connect. I have unistalled and reinstalled. I get this msg: Server Unavailable. Please explain how to resolve this issue ASAP.
9 Comments
Support Team posted this 5 days ago
Please try the following:
1) close Themler
4) start Themler again
Hello, Please try the following: 1) close Themler 2) open Windows Explorer and type %LocalAppData% in the address bar 3) find & rename Themler directory 4) start Themler again Sincerely, Nettie
scott
scott posted this 4 days ago
That did not work. It appears the server error is only happening when designing a DNN theme. Any idea why that is??? as it is the primary reason why I use Themler.
scott
Support Team posted this 3 days ago
Scott,
I can confirm this issue, it happens on my end as well with DNN theme only.
This is reported to the developers.
I will let you know when it is fixed.
Scott, I can confirm this issue, it happens on my end as well with DNN theme only. This is reported to the developers. I will let you know when it is fixed. Gina Themler Support
flaviasoul
flaviasoul posted this 3 days ago
Mine don't work too... In edge or Chrome, don't work... when i try to log in, it dissapear and appear in a looping... i can't close the window... please what's wrong?
scott
scott posted this 3 days ago
Correct. The problem is when designing the DNN theme. Which I need. When will this be corrected?
Kaatt
Kaatt posted this 3 days ago
I get the same problem with a Joomla theme as well...
We have updated our server for this issue for older themes. To have it work, you need to clear the cache again. If you are using Google Chrome, try this:
1) navigate to:
chrome://appcache-internals
2) navigate to:
1) close Themler
We have updated our server for this issue for older themes. To have it work, you need to clear the cache again. If you are using Google Chrome, try this: 1) navigate to: chrome://appcache-internals find your website and click on 'Remove Item' 2) navigate to: chrome://settings/clearBrowserData select 'Cached images and files ' and click on 'Clear Data' (please don't check other check-boxes). 3) Reload your Themler Editor. Some users have reported that complete re-install of Google Chrome solved the issue. If you are using the Desktop version, then: 1) close Themler 2) open Windows Explorer and type %LocalAppData% in the address bar 3) find & rename Themler directory 4) start Themler again Gina Themler Support
scott
Is Solution
scott posted this 2 days ago
Worked! Thank you so much!!!!!!
