Editor Window not scrolling using JCE Editor
SRuff
SRuff posted this 12 August 2015
Joomla 3.4.3
Default Editor - JCE
When editing content, I cannot scroll to the bottom of the page in the editor window.
When I switch to tinyMCE the scrolling feature works fine.
I assume it has something to do with the editor css in my Themler template, but I'm not that savvy to figure it out.
Thank you for you help.
Joomla 3.4.3 Default Editor - JCE When editing content, I cannot scroll to the bottom of the page in the editor window. When I switch to tinyMCE the scrolling feature works fine. I assume it has something to do with the editor css in my Themler template, but I'm not that savvy to figure it out. Thank you for you help.
13 Comments
Support Team posted this 13 August 2015
Sent to development team.
Support Team posted this 14 August 2015
Hi Scott,
Actually, I wasn't able to reproduce the issue.
Could you please try to install the latest version of JCE editor and let us know if the issue still persists.
Ivan
Hi Scott, Actually, I wasn't able to reproduce the issue. Could you please try to install the latest version of JCE editor and let us know if the issue still persists. Thanks, Ivan
SRuff
SRuff posted this 14 August 2015
JCE is up to date. Version: 2.5.2
If I use the Code View the scrolling works fine. But it still doesn't work in the regular edit view.
JCE Settings are as follows:
JCE Settings 1
JCE Settings 2
JCE Settings 3
JCE is up to date. Version: 2.5.2 If I use the Code View the scrolling works fine. But it still doesn't work in the regular edit view. JCE Settings are as follows: ![JCE Settings 1][1] ![JCE Settings 2][2] ![JCE Settings 3][3] [1]: http://nl-godstory.com/Delete/1.png [2]: http://nl-godstory.com/Delete/2.png [3]: http://nl-godstory.com/Delete/3.png
SRuff
UPDATE: I logged out and logged back in after updating and now it works. Thanks!
SRuff
SRuff posted this 15 August 2015
UPDATE Very Important: I found the problem.
If the JCE Editor is set to "Use Default" there is no scrolling problem. But if editor is set to "Template Default CSS" then it won't scroll.
**UPDATE Very Important: I found the problem.** If the JCE Editor is set to "Use Default" there is no scrolling problem. But if editor is set to "Template Default CSS" then it won't scroll.
Pierre665
Pierre665 posted this 17 August 2015
I have the same problem...
Hi, I have the same problem...
Support Team posted this 18 August 2015
Hello guys,
please check my response in the topic http://answers.themler.com/questions/19878/editor-not-scrolling-when-using-jce where the same issue is being discussed.
Hello guys, please check my response in the topic http://answers.themler.com/questions/19878/editor-not-scrolling-when-using-jce where the same issue is being discussed. regards, Aileen
tmgarrison
tmgarrison posted this 09 December 2015
Aileen,
It's December 9, 2015 and I'm having the exact same issue.
I can switch to the TinyMCE editor and it works fine. JCE "was" working just fine until today. I'd been using it, editing and suddenly the scroll bar didn't work from top to bottom - only to just a bit longer than the visual size of the window. Any content below the visual window area was unavailable without using the down arrow key to force the screen to scroll.
When I switched to "Global Configuration > Formatting & Display > Reset Editor Styling > Yes", there are 2 scroll bars on the right and both are needed in order to go from top to bottom. Extremely annoying.
Also, the link to your "Answer" has been removed.
It's obvious this is something with Themler since I've never experienced this with Joomla in more than 7 years, and I found the issue only here in Themler...and I'm using a Themler template I'm trying to complete.
I even switched to TinyMCE, uninstalled JCE, then reinstalled to see if that would help....it did not. However, I did not close out my browser to clear any cache. I'll do that now, but I'm not hopeful.
Aileen, It's December 9, 2015 and I'm having the exact same issue. I can switch to the TinyMCE editor and it works fine. JCE "was" working just fine until today. I'd been using it, editing and suddenly the scroll bar didn't work from top to bottom - only to just a bit longer than the visual size of the window. Any content below the visual window area was unavailable without using the down arrow key to force the screen to scroll. When I switched to "Global Configuration > Formatting & Display > Reset Editor Styling > Yes", there are 2 scroll bars on the right and both are needed in order to go from top to bottom. Extremely annoying. Also, the link to your "Answer" has been removed. It's obvious this is something with Themler since I've never experienced this with Joomla in more than 7 years, and I found the issue only here in Themler...and I'm using a Themler template I'm trying to complete. I even switched to TinyMCE, uninstalled JCE, then reinstalled to see if that would help....it did not. However, I did not close out my browser to clear any cache. I'll do that now, but I'm not hopeful.
tmgarrison
tmgarrison posted this 11 December 2015
I concur with SRuff.
I didn't make that change before I posted last.
I've just made the change to "Default" and yes....the scroll bar works fine.
Thank you for that, SRuff.
I concur with SRuff. I didn't make that change before I posted last. I've just made the change to "Default" and yes....the scroll bar works fine. Thank you for that, SRuff.
Support Team posted this 15 December 2015
Hello Thomas,
please submit new private topic and provide access to your Joomla admin back end.
Hello Thomas, please submit new private topic and provide access to your Joomla admin back end. regards, Aileen
I've just converted the topic http://answers.themler.com/questions/48977/page-template-for-joomla-is-not-working to private, so lets continue the discussion about the JCE Editor in that topic.
Hi, I've just converted the topic http://answers.themler.com/questions/48977/page-template-for-joomla-is-not-working to private, so lets continue the discussion about the JCE Editor in that topic. Regards, Aileen
emailrobind
emailrobind posted this 21 February 2021
Same issue here, can't scroll up or down in editor window
Support Team posted this 22 March 2021
Hello Robin,
I apologize for the delay.
Please, try the solution from here https://answers.themler.io/questions/19878/editor-not-scrolling-when-using-jce
If it doesn't work, please, create new private topic with temporary access to the site.
Themler support
Hello Robin, I apologize for the delay. Please, try the solution from here https://answers.themler.io/questions/19878/editor-not-scrolling-when-using-jce If it doesn't work, please, create new private topic with temporary access to the site. Thank you Gina Themler support
