virtuemart category css copy
tamas
tamas posted this 16 April 2020
category css can be copied? to subcategory?
Hello category css can be copied? to subcategory? Thank you
6 Comments
Support Team posted this 16 April 2020
You may try to do this manually in the css file - please back up the theme before this. However we recommend just to set the same for the subcategories in the Products tab >> Categories >> Subcategories.
Hello, You may try to do this manually in the css file - please back up the theme before this. However we recommend just to set the same for the subcategories in the Products tab >> Categories >> Subcategories. Sincerely, Nettie
tamas
but how could you show a picture?
Support Team posted this 17 April 2020
For the image - the initial settings for the images from Virtuemart are taken. Please compare the original uploaded image with the one from the category and try to make it the same size.
Hello, For the image - the initial settings for the images from Virtuemart are taken. Please compare the original uploaded image with the one from the category and try to make it the same size. Sincerely, Nettie
tamas
tamas posted this 17 April 2020
css format not same category subcategory
I copy categori css same format for subcategory.....
don't edit again subcategory!!!!!!!!
Copy category to subcategory.
Do you understand
css format not same category subcategory I copy categori css same format for subcategory..... don't edit again subcategory!!!!!!!! Copy category to subcategory. Do you understand
tamas
tamas posted this 18 April 2020
can't I copy a specific format?
do you always have to start over?
is there no technique for this?
can't I copy a specific format? do you always have to start over? is there no technique for this?
Support Team posted this 29 April 2020
You can copy style fo separate controls - for example, a Category image. For this right-click the control, select Copy Style. Then right-click another control and select Paste Style. But there is unfortunately no option to copy the structure and style for the whole Categories to Subcategories.
Sincerely
Hello, You can copy style fo separate controls - for example, a Category image. For this right-click the control, select Copy Style. Then right-click another control and select Paste Style. But there is unfortunately no option to copy the structure and style for the whole Categories to Subcategories. Sincerely Nettie
