Hi. I have the above error and no page content will load. Can anyone assist?
Hi. I have the above error and no page content will load. Can anyone assist?Hello,
What happened before the issue has appeared? Have you edited or resized some image in the theme?
Just routine updates - todays minor joomla update and php was updated to 7.3. I get other errors when I revert php to older version.
Themler is probably outdated but I can't get the editor to run in Admin, so can't get the latest version
Have a dev looking at this right now
Just routine updates - todays minor joomla update and php was updated to 7.3. I get other errors when I revert php to older version. Themler is probably outdated but I can't get the editor to run in Admin, so can't get the latest version Have a dev looking at this right nowDo you remember what version of Themler your theme has?
Try to get the theme from your server (via FTP go to "templates" folder, copy this theme folder and zip it on your local drive) and update it with Themler Desktop, then re-install.
It turned out to be a buggy module crashing the page. Fixed.
I do have the latest Themler version now though, so thanks for that advice.
It turned out to be a buggy module crashing the page. Fixed. I do have the latest Themler version now though, so thanks for that advice.Last edited 22 April 2020 by mrvargo
Thanks for letting us know. Just in case, we recommend to update Themler theme each time before updating Joomla or PHP, newer versions usually include support for new CMS's or PHP versions.
