for the site dekaashoekkortrijk.be i have a very strange problem. De section "specialiteiten" is not visible in mozilla, but seems ok in other browsers.
Please some help.
Please some help.
I use mozilla and no problem to view for me.
Best regards
Malinka
Hello Kris,
Same here, no problems (it must be cache on your side):
ok i had 2 sections in the home area, and that cause the problem. Now i changed 1 section to the header and everythings seems ok. Because it's a one page this tric helps, but what if the site have multiple pages?
ok i had 2 sections in the home area, and that cause the problem. Now i changed 1 section to the header and everythings seems ok. Because it's a one page this tric helps, but what if the site have multiple pages?for the record see for yourselves https://test-ararin.be/test3/
for the record see for yourselves https://test-ararin.be/test3/Bootstrap autocalculates margin and it conflicts with Firefox display, for some reason. Try adding this code to Home -> Settings -> Additional CSS:
.bd-layoutcontainer-25 > .bd-container-inner > .container-fluid > .row {margin:auto!important;}
Themler support
Your work stands out to me because it's interesting and easy to understand candy clicker 2. I've read a lot of blogs, but I still like yours better. It was interesting to read your paper. I understand the article better now that I've read it several times. Going forward, I'd like to read more of what you write.
Your work stands out to me because it's interesting and easy to understand [candy clicker 2][1]. I've read a lot of blogs, but I still like yours better. It was interesting to read your paper. I understand the article better now that I've read it several times. Going forward, I'd like to read more of what you write. [1]: https://candyclicker2.com
