Header slider
Aileen posted this 10 April 2014
Is it possible to change the part of visible area of the slide? Or resize the slide to fit Header size?
Is Solution
Olivia posted this 11 April 2014
Hi Aileen,
Unfortunately your first question is not quite clear to me :)
Could you please explain it a little including the screenshots?
You can resize the Slider under the Slider Tab in PW >> Layout:
alt text
Hi Aileen, Unfortunately your first question is not quite clear to me :) Could you please explain it a little including the screenshots? > Or resize the slide to fit Header size? You can resize the Slider under the Slider Tab in PW >> Layout: ![alt text](http://attachments.forum.billiondigital.com/29/29/slider-width.png "slider-width.png") Thanks, Olivia
Aileen posted this 16 April 2014
The background size of the slider could be specified under under Background options marked on the screenshot
The background size of the slider could be specified under under Background options marked on the screenshot ![](http://attachments.forum.billiondigital.com/82/82/SliderBackground.png)
Support Team posted this 16 April 2014
Solution found.
Solution found.
