Home page images on mobile blurry
ernasziky
ernasziky posted this 14 May 2020
I'm having an issue with the images on the home page. When the website is opened from a mobile phone (specially iPhone), the images are blurry.
On desktop though, doesn't happen the same.
Can you please advise how to fix the issue?
website: www.nesshoes.com
Hello, I'm having an issue with the images on the home page. When the website is opened from a mobile phone (specially iPhone), the images are blurry. On desktop though, doesn't happen the same. Can you please advise how to fix the issue? website: www.nesshoes.com Thank you
12 Comments
Support Team posted this 18 May 2020
Hello Erna,
I couldn't see this issue on my iPhone or while simulating phone modes in a browser.
I have attached screenshot for reference.
Themler doesn't have any settings or built-in login to optimize image quality for responsive modes. They are get resized, that's all.
Hello Erna, I couldn't see this issue on my iPhone or while simulating phone modes in a browser. I have attached screenshot for reference. Themler doesn't have any settings or built-in login to optimize image quality for responsive modes. They are get resized, that's all. Gina Themler Support
ernasziky
ernasziky posted this 19 May 2020
Hello Gina,
Thank you for your answer.
However notice that in your attachment, only a section of the home page is captured.
If you take a look at the slides on the top and the section where the contact details are, you'll see that they are indeed blurry.
I also assumed that Themler would only resized the picture, but in this case, it seems not to be working.
Can you please have a look at it again?
Thank you in advance.
Hello Gina, Thank you for your answer. However notice that in your attachment, only a section of the home page is captured. If you take a look at the slides on the top and the section where the contact details are, you'll see that they are indeed blurry. I also assumed that Themler would only resized the picture, but in this case, it seems not to be working. Can you please have a look at it again? Thank you in advance.
Support Team posted this 20 May 2020
I see what you mean. They are scaled too much due to parallax background. I assume you used parallax there. Try changing the scaling for the background. You can provide temporary access to the site so we could try changing settings as well.
I see what you mean. They are scaled too much due to parallax background. I assume you used parallax there. Try changing the scaling for the background. You can provide temporary access to the site so we could try changing settings as well. Gina Themler Support
ernasziky
ernasziky posted this 20 May 2020
Hello Gina,
Thank you for your response.
Do you need temporary access to the Wordpress site? By temporary access you mean credentials right?
Thank you!
Hello Gina, Thank you for your response. Do you need temporary access to the Wordpress site? By temporary access you mean credentials right? Thank you!
Yes, to both questions.
Yes, to both questions. Gina
ernasziky
email: erna.sziky@gmail.com
password: NESshoesxNESTTA2020
https://nesshoes.com/wp-admin/
Erna
email: erna.sziky@gmail.com password: NESshoesxNESTTA2020 https://nesshoes.com/wp-admin/ Regards, Erna
Support Team posted this 21 May 2020
When I open the link, it says that the page is temporary unavailable.
When I open the link, it says that the page is temporary unavailable. Gina Themler Support
ernasziky
ernasziky posted this 21 May 2020
That's weird.
Can you please try again now?
Erna
That's weird. Can you please try again now? Regards, Erna
Support Team posted this 22 May 2020
I was able to access now.
I can't see any "wrong" setting in Themler that might cause this, I was also not able to reproduce it in responsive modes either in Themler or in a browser developer mode.
What you can try:
1) try disabling overlay effect, see if it helps for the slider
2) try changing the size of the background for every slide from cover to contain. You can try other options as well. Do this while in responsive mode.
I was able to access now. I can't see any "wrong" setting in Themler that might cause this, I was also not able to reproduce it in responsive modes either in Themler or in a browser developer mode. What you can try: 1) try disabling overlay effect, see if it helps for the slider 2) try changing the size of the background for every slide from cover to contain. You can try other options as well. Do this while in responsive mode. !Screenshot-1.png! Gina Themler Support
jabeko4536
jabeko4536 posted this 23 November 2025
Hola, entiendo lo frustrante que es cuando las imágenes se ven borrosas en móviles y todo parece correcto en escritorio; me ha pasado algo parecido al probar varias webs desde mi iPhone. Mientras investigaba soluciones para optimizar imágenes, encontré felixspin casino y noté que ofrecen promociones especiales para jugadores en España. Aproveché un rato para probar unas partidas de ruleta y, aunque al principio no tuve suerte, luego una combinación me dio un premio que me alegró la tarde. Fue curioso cómo pequeños ajustes y pruebas, ya sea en desarrollo web o juegos, pueden traer resultados positivos.
Hola, entiendo lo frustrante que es cuando las imágenes se ven borrosas en móviles y todo parece correcto en escritorio; me ha pasado algo parecido al probar varias webs desde mi iPhone. Mientras investigaba soluciones para optimizar imágenes, encontré [felixspin casino][1] y noté que ofrecen promociones especiales para jugadores en España. Aproveché un rato para probar unas partidas de ruleta y, aunque al principio no tuve suerte, luego una combinación me dio un premio que me alegró la tarde. Fue curioso cómo pequeños ajustes y pruebas, ya sea en desarrollo web o juegos, pueden traer resultados positivos. [1]: https://felix-spin.com.es
aydenvlnzl
aydenvlnzl posted this 14 February 2026
Many users notice that images on their website’s home page appear blurry when viewed on mobile devices. This issue often arises due to low-resolution images being scaled to fit smaller screens, improper compression, or lack of responsive image optimization. Ensuring high-quality image files and using adaptive image techniques can significantly enhance clarity and provide a sharper, more professional appearance across all devices.
To maintain crisp visuals and support multiple formats, platforms like https://imgrr.com/
offer a reliable solution to edit, optimize, and convert images into JPG, PNG, WEBP, BMP, PDF, and more. By leveraging such tools, users can enhance image resolution, compress files without losing quality, and ensure that visuals appear sharp on both desktop and mobile screens. This makes managing, sharing, and displaying images effortless while keeping your website visually appealing.
Many users notice that images on their website’s home page appear blurry when viewed on mobile devices. This issue often arises due to low-resolution images being scaled to fit smaller screens, improper compression, or lack of responsive image optimization. Ensuring high-quality image files and using adaptive image techniques can significantly enhance clarity and provide a sharper, more professional appearance across all devices. To maintain crisp visuals and support multiple formats, platforms like https://imgrr.com/ offer a reliable solution to edit, optimize, and convert images into JPG, PNG, WEBP, BMP, PDF, and more. By leveraging such tools, users can enhance image resolution, compress files without losing quality, and ensure that visuals appear sharp on both desktop and mobile screens. This makes managing, sharing, and displaying images effortless while keeping your website visually appealing.
floridachilds692
floridachilds692 posted this 06 May 2026
Mobile image quality can really affect how a site feels on smaller screens especially when product details matter and users are zooming in for a closer look. In outdoor gear spaces where sharp visuals help people compare equipment like StrikeMaster auger blades clear mobile optimization makes a noticeable difference in user experience. Sometimes the issue is less about the image itself and more about how compression and responsive sizing are handled across devices
Mobile image quality can really affect how a site feels on smaller screens especially when product details matter and users are zooming in for a closer look. In outdoor gear spaces where sharp visuals help people compare equipment like [StrikeMaster][1] auger blades clear mobile optimization makes a noticeable difference in user experience. Sometimes the issue is less about the image itself and more about how compression and responsive sizing are handled across devices [1]: https://strike-master.com/auger-blades/
