themler login
EMIN_ASKEROV
EMIN_ASKEROV posted this 16 May 2020
Hi.
I installed a Themler and i want to start it not in a browser but separate. But i want to link it to my joomla control panel.
So far I can not get a success, that same joomla to work in Themler and in Joola control panel.
Shall i use the same login which i use when i login into joomla control panel?
Hi. I installed a Themler and i want to start it not in a browser but separate. But i want to link it to my joomla control panel. So far I can not get a success, that same joomla to work in Themler and in Joola control panel. Shall i use the same login which i use when i login into joomla control panel?
EMIN_ASKEROV
the reason why i am doing it that I want to import and export zip archives.
Support Team posted this 18 May 2020
For Themler please use email you have registered Themler with, both in Themler desktop or on a website.
There are several options to work with Themler.
1. Download Themler desktop. It installs own localhost with CMS's.
2. Download default Themler theme and work at it on your localhost or hosted website with the preferred CMS (in this case you will use the admin panel of your website).
In both cases you will be able to export and import theme as ZIP at any time.
Hello, For Themler please use email you have registered Themler with, both in Themler desktop or on a website. There are several options to work with Themler. 1. Download Themler desktop. It installs own localhost with CMS's. 2. Download default Themler theme and work at it on your localhost or hosted website with the preferred CMS (in this case you will use the admin panel of your website). In both cases you will be able to export and import theme as ZIP at any time. Sincerely, Nettie
