what happens if i delete the editor folder from themler's template?
jmoises
jmoises posted this 18 May 2020
Hi!
I need to take weight off the site. If I open the editor folder I see that I have the same files that are outside.
So my question is if i delete that folder what happen? or if i delete the same files that been outside of editor folder and i keep the editor folder what happen?
Hi! I need to take weight off the site. If I open the editor folder I see that I have the same files that are outside. So my question is if i delete that folder what happen? or if i delete the same files that been outside of editor folder and i keep the editor folder what happen?
Support Team posted this 19 May 2020
This folder makes it possible to open and edit the theme in Themler. You will be not possible to edit the theme. You may make a theme copy, and then re-export the theme without Include Themler option. It will make it smaller.
Hello, This folder makes it possible to open and edit the theme in Themler. You will be not possible to edit the theme. You may make a theme copy, and then re-export the theme without Include Themler option. It will make it smaller. Sincerely, Nettie
