can't save anything!
Phil Sanz
Phil Sanz posted this 3 weeks ago
i can't change anything. i click on save, the window to sign in appears but it flash all the time...i saw on the forum someone who got the same problem..you gives a solution but in my case it don 't work... have you another soluton?
Thanks for your support.
1) Open this URL in Chrome:
chrome://appcache-internals
2) Open this URL in Chrome:
Hi, i can't change anything. i click on save, the window to sign in appears but it flash all the time...i saw on the forum someone who got the same problem..you gives a solution but in my case it don 't work... have you another soluton? Thanks for your support. 1) Open this URL in Chrome: chrome://appcache-internals find your website and click on 'Remove Item' 2) Open this URL in Chrome: chrome://settings/clearBrowserData select 'Cached images and files ' and click on 'Clear Data' (please don't check other check-boxes).
Hello Phil,
Does it happen in Chrome only or in all browsers? Try Firefox.
I will paste the solution below (I know you tried it, but just in case you haven't tried the option for desktop):
1) navigate to:
2) navigate to:
1) close Themler
4) start Themler again
Hello Phil, Does it happen in Chrome only or in all browsers? Try Firefox. I will paste the solution below (I know you tried it, but just in case you haven't tried the option for desktop): If you are using Google Chrome, try this: 1) navigate to: chrome://appcache-internals find your website and click on 'Remove Item' 2) navigate to: chrome://settings/clearBrowserData select 'Cached images and files ' and click on 'Clear Data' (please don't check other check-boxes). 3) Reload your Themler Editor. Some users have reported that complete re-install of Google Chrome solved the issue. If you are using the Desktop version, then: 1) close Themler 2) open Windows Explorer and type %LocalAppData% in the address bar 3) find & rename Themler directory 4) start Themler again Gina Themler Support
Phil Sanz
Phil Sanz posted this 2 weeks ago
ok it s works with firefox!!!
It's kind of weird?
Thank you for you support :)
ok it s works with firefox!!! It's kind of weird? Thank you for you support :)
There used to be an issue related to recent changes in Chrome browser. It has been fixed, however for correct work the steps provided above are necessary. Sometimes only complete reinstallation of Chrome browser helps but usually the mentioned steps are sufficient.
Hello, There used to be an issue related to recent changes in Chrome browser. It has been fixed, however for correct work the steps provided above are necessary. Sometimes only complete reinstallation of Chrome browser helps but usually the mentioned steps are sufficient. Sincerely, Nettie
