Add section in Joomla
fred_doan
fred_doan posted this 09 June 2020
Hello supports,
For the same section (e.g. Six Columns Header) from the libraries, when I add it into Article: Home, it would work as expected when I click on the images (popup and cycle through all images) but if I add it into Template: Home, it would not. Is this a bug or how do I fix this for Template: Home location?
Fred
Hello supports, For the same section (e.g. Six Columns Header) from the libraries, when I add it into Article: Home, it would work as expected when I click on the images (popup and cycle through all images) but if I add it into Template: Home, it would not. Is this a bug or how do I fix this for Template: Home location? Thanks, Fred
Support Team posted this 09 June 2020
Hello Fred,
If I understand correctly what you mean, it is a Header section - it is supposed to be a Header and not to be added in content area.
Hello Fred, If I understand correctly what you mean, it is a Header section - it is supposed to be a Header and not to be added in content area. Sincerely, Nettie
fred_doan
Hello Nettie,
No, it's not the header section. Please see attached image below.
Fred
Hello Nettie, No, it's not the header section. Please see attached image below. Thank you, Fred!section-issue.jpg!
Support Team posted this 10 June 2020
Hello Fred,
When something is added to the blue area (you can see that Template:Home is blue) , it becomes static content and is written directly to php files. You can't manage it via CMS and it can't perform as CMS content.
Green area is manageable via CMS.
In your case you may want to add this 6 header section to a joomla position or a top sidebar, so it is not part of the article but yet is part of CMS content.
Hello Fred, When something is added to the blue area (you can see that Template:Home is blue) , it becomes static content and is written directly to php files. You can't manage it via CMS and it can't perform as CMS content. Green area is manageable via CMS. In your case you may want to add this 6 header section to a joomla position or a top sidebar, so it is not part of the article but yet is part of CMS content. Gina Themler Support
