When i want to log in to Themler Joomla Template on themove.be i have a blank login popup. Can't login, Chrome and Safari on Mac.
Can you help me ?
grt
Alain
Can you help me ?
grt
Alain
For Themler on the hosted website please follow these steps:
1) Open this URL in Chrome:
chrome://appcache-internals
2) Open this URL in Chrome:
Hi Nettie,
Sorry doesn't help..
REgards,
Alain
Let's try it for Safari:
1. Disable the option "Prevent cross-data tracking" in Safari browser
2. Reboot the computer.
3. Run Themler and log in.
4. Try to save and export the theme and let us know the result.
Also please try to run Themler in Firefox browser.
Doesn't work neither. This my seconds site with the same problem.
I had a ticket last year for boekhouding.com with the same problem.
So it is impossible to change both sites. Serieus issue...
I suppose all my sites will have the same problem after soms time ?
I need help .
Alain
Hello, Doesn't work neither. This my seconds site with the same problem. I had a ticket last year for boekhouding.com with the same problem. So it is impossible to change both sites. Serieus issue... I suppose all my sites will have the same problem after soms time ? I need help . Regards, AlainI had to change the phone number on homepage themove.be can you tell me where to find in code ? ftp
I had to change the phone number on homepage themove.be can you tell me where to find in code ? ftpHello,
Looks to be rather browser or caching issue. As a temporary solution we would recommend to find the theme via FTP, zip-compress it and import it in Themler desktop for Windows or for Mac, then work at it, export and install it back.
To correct the number please take the theme folder and search by text (number in this case).
