Hi all,
I would like to ask you for help once again with my Themler theme on page http://cnchs.karosa.eu. I need to have a Polylang language switcher in my main menu.
In your response to my topic: "https://answers.themler.io/questions/200382/polylang-menu-issue" you gave me some tips for solution but it does not work, unfortunately.
I tried to insert language "minimenu" as described in previous topic (see link above). But I have several troubles with this solution:
1) I cannot find where to hide French and German. I wanna use only Czech and English.
2) I am not able to display flags only.
3) After switching to English I cannot switch back to Czech.
I would like to have only the flag as a part of main menu. See this link: www.czech-neurosurgery.cz. This is also my Themler theme but main menu is made by MegaMenu plugin. I think that is nonsense to use MaxMegaMenu plugin in each case of PolyLang plugin usage. Themler should be able to provide this. I also tried to use MaxMegaMenu plugin as in my www.czech-neurosurgery.cz web. But that plugins does not work.
So, I want to ask you for help to solve it. An issue with placing polylang language swither into menu would help me to solve it in several webs. I prefer to place Polylang language switcher instead of Themler's one.
I am absolutelly unhappy with that :-(
Please once again for you help
Best regards
Míra
Hi all, I would like to ask you for help once again with my Themler theme on page http://cnchs.karosa.eu. I need to have a Polylang language switcher in my main menu. In your response to my topic: "https://answers.themler.io/questions/200382/polylang-menu-issue" you gave me some tips for solution but it does not work, unfortunately. I tried to insert language "minimenu" as described in previous topic (see link above). But I have several troubles with this solution: 1) I cannot find where to hide French and German. I wanna use only Czech and English. 2) I am not able to display flags only. 3) After switching to English I cannot switch back to Czech. I would like to have only the flag as a part of main menu. See this link: www.czech-neurosurgery.cz. This is also my Themler theme but main menu is made by MegaMenu plugin. I think that is nonsense to use MaxMegaMenu plugin in each case of PolyLang plugin usage. Themler should be able to provide this. I also tried to use MaxMegaMenu plugin as in my www.czech-neurosurgery.cz web. But that plugins does not work. So, I want to ask you for help to solve it. An issue with placing polylang language swither into menu would help me to solve it in several webs. I prefer to place Polylang language switcher instead of Themler's one. I am absolutelly unhappy with that :-( Please once again for you help Best regards MíraLast edited 15 June 2020 by miroslav.cihlo
