images deformation
ivokk
ivokk posted this 19 June 2020
I am doing a site in drupal with themler.
I gave an issue with a images .
When I put an image on a page it deforming and actually the problem is in the height.
Can you advice me how to solve the problem
I am attaching a published vaiant and an original.
https://np-plast.com/node/34
Hello, I am doing a site in drupal with themler. I gave an issue with a images . When I put an image on a page it deforming and actually the problem is in the height. Can you advice me how to solve the problem I am attaching a published vaiant and an original. https://np-plast.com/node/34
Support Team posted this 20 June 2020
There is max-height:200px; set to images in posts.
In Themler open Post, Page and Blog templates in turn, and then click inside the post content, go to Post Image and set Max Height (under More Options) to auto or 100%. See which works best.
If you need help with that, please share temporary access.
Hello, There is max-height:200px; set to images in posts. In Themler open Post, Page and Blog templates in turn, and then click inside the post content, go to Post Image and set Max Height (under More Options) to auto or 100%. See which works best. If you need help with that, please share temporary access. Gina Themler Support
ivokk
ivokk posted this 21 June 2020
Helloq
Thank you very much.
Is this setting is global or I have to change for every post?
Ho can I change for example for all posts in case it is only for one .
Actuyaly this i would like to remove for all posts.
BR
Ivo
Helloq Thank you very much. Is this setting is global or I have to change for every post? Ho can I change for example for all posts in case it is only for one . Actuyaly this i would like to remove for all posts. BR Ivo
Support Team posted this 22 June 2020
When you do it for Post, Page and Blog templates, it will be applied on the site in general.
When you do it for Post, Page and Blog templates, it will be applied on the site in general. Gina Themler Support
