Why is Themler so slow? Let us reason
benjamin-der-friese
benjamin-der-friese posted this 20 June 2020
Themler UI has, for the most part, delays up to 1-2 seconds when changing parameters on a Quadcore 2.6 Ghz, Windows 10, 4 GB Ram, 256 GByte Samsung SSD. This is not acceptable. For me, the design process is something which should be fluid, alive, creative, not something that has to deal with technical "limitations" on each change ifrom the UI. Could you make it faster, more reliable, slick, professional and more high quality? Even if your software cost more money to obtain, I would pay the price. It IS not only something which could be done, but should be done. Or I change to Elementor. You have to ACT NOW.
21 Comments
Support Team posted this 22 June 2020
Looks like something is interferring into the process - some third-party application or internet speed may matter, or some VPN or proxy, because Themler needs to contact to servers from time to time.
In any case, we would recommend some alternative solutions like installing a theme in CMS on some localhost or hosted website and work at it there - it can be faster.
Also you may wish to consider Nicepage as a simpler and faster application, though it is different from Themler, but it may fit your needs:
https://nicepage.com/
Hello, Looks like something is interferring into the process - some third-party application or internet speed may matter, or some VPN or proxy, because Themler needs to contact to servers from time to time. In any case, we would recommend some alternative solutions like installing a theme in CMS on some localhost or hosted website and work at it there - it can be faster. Also you may wish to consider Nicepage as a simpler and faster application, though it is different from Themler, but it may fit your needs: https://nicepage.com/ Sincerely, Nettie
benjamin-der-friese
benjamin-der-friese posted this 22 June 2020
I said UI, not internet.
Support Team posted this 23 June 2020
In any case, it may be faster in CMS on some hosted or local server, please feel free to try.
Hello, In any case, it may be faster in CMS on some hosted or local server, please feel free to try. Sincerely, Nettie
mz.musical
Is Solution
mz.musical posted this 23 June 2020
I had the same problem, and I know a lot of people have it
But I managed to fix the problem of themler being slow
This problem is not related to third-party application or internet speed or some VPN or proxy or hosted or local server and It doesn't even matter how much processing power your system has
I can help you if you want.
Hello I had the same problem, and I know a lot of people have it But I managed to fix the problem of themler being slow This problem is not related to third-party application or internet speed or some VPN or proxy or hosted or local server and It doesn't even matter how much processing power your system has I can help you if you want. Sincerely,
benjamin-der-friese
benjamin-der-friese posted this 23 June 2020
that would be great.
> Hello > I had the same problem, and I know a lot of people have it > But I managed to fix the problem of themler being slow > This problem is not related to third-party application or internet speed or some VPN or proxy or hosted or local server and It doesn't even matter how much processing power your system has > I can help you if you want. > Sincerely, that would be great.
mz.musical
Very well
So send me a message in the Telegram app to guide you
My ID is: @webmanifest
Very well So send me a message in the Telegram app to guide you My ID is: @webmanifest
benjamin-der-friese
my telegram only accepts cellphone numbers, not aliases
mz.musical
I can't share my cellphone number here
You give your ID
I can't share my cellphone number here You give your ID
benjamin-der-friese
let me check Google how to assign an ID
mz.musical
ok
> let me check Google how to assign an ID ok
benjamin-der-friese
I opened a chat with you 😀
mgarcia
mgarcia posted this 27 June 2020
Try to stop your antivirus.
Ive disabled temporarily my AV and works better. Dont forget to check your internet speed also.
Try to stop your antivirus. Ive disabled temporarily my AV and works better. Dont forget to check your internet speed also.
benjamin-der-friese
benjamin-der-friese posted this 27 June 2020
today's games which are thousand times more cpu heavy than themler process data more reliable for steady frame rates.
maybe I just have accept that themler has no game engine quality?
I don't believe that any normal AV reduces Themler's speed by the factor 1 to 5.
today's games which are thousand times more cpu heavy than themler process data more reliable for steady frame rates. maybe I just have accept that themler has no game engine quality? I don't believe that any normal AV reduces Themler's speed by the factor 1 to 5.
tomeek884
tomeek884 posted this 29 June 2020
I was helped by the addition of 8gb ramu and ssd disk (currently 12g ramu) and now it runs smoothly but it cuts. I would ask for this instruction by e-mail
strony.rwd@gmail.com
best regards
I was helped by the addition of 8gb ramu and ssd disk (currently 12g ramu) and now it runs smoothly but it cuts. I would ask for this instruction by e-mail strony.rwd@gmail.com best regards
benjamin-der-friese
benjamin-der-friese posted this 29 June 2020
understand this!
it's not about who has got the most RAM, but that free RAM is present when memory operations are being performed and this is the case in my scenario.
understand this! it's not about who has got the most RAM, but that free RAM is present when memory operations are being performed and this is the case in my scenario.
agemmaackson
agemmaackson posted this 14 April 2025
To fix the game lag or high latency can be replaced with apk premium games, opening up an extremely attractive and rich game world.
To fix the game lag or high latency can be replaced with [apk premium][1] games, opening up an extremely attractive and rich game world. [1]: https://seruapk.com/
annmuelleroil2785878
annmuelleroil2785878 posted this 23 April 2025
​Totally feel you on the Themler struggle it's like trying to run a high-end game on a potato. The lag is unreal, and the lack of updates or support just adds to the frustration.​If you're looking for smoother alternatives, check out https://apkjaka.com/ . They've got a solid collection of APKs and tools that might just make your workflow a whole lot easier. It's like finding a secret level in a game unexpected but totally worth it.​
gokutto1
gokutto1 posted this 20 June 2025
I understand your frustration with Themler UI's performance. For an optimal design experience, it's essential that the interface is smooth and responsive. Performance issues like delays can stem from various factors such as software optimization or system compatibility. We continuously work on improving the user experience, and feedback like yours is valuable in guiding future updates. I recommend checking for the latest updates to ensure you're using the most optimized version.
For further details and potential solutions, you can check out more at https://apkdescargar.io/
I understand your frustration with Themler UI's performance. For an optimal design experience, it's essential that the interface is smooth and responsive. Performance issues like delays can stem from various factors such as software optimization or system compatibility. We continuously work on improving the user experience, and feedback like yours is valuable in guiding future updates. I recommend checking for the latest updates to ensure you're using the most optimized version. For further details and potential solutions, you can check out more at https://apkdescargar.io/
zany.gazelle.kqrd
zany.gazelle.kqrd posted this 28 August 2025
Themler's UI lag is a real buzzkill. Waiting seconds for parameter changes on a decent machine disrupts the creative flow. It's like hitting an icy patch in Snow Rider 3D, totally throws you off course! Speed and reliability are key. A fluid design process is essential, even if it means investing more. Otherwise, Elementor is looking pretty appealing.
Themler's UI lag is a real buzzkill. Waiting seconds for parameter changes on a decent machine disrupts the creative flow. It's like hitting an icy patch in [Snow Rider 3D][1], totally throws you off course! Speed and reliability are key. A fluid design process is essential, even if it means investing more. Otherwise, Elementor is looking pretty appealing. [1]: https://snowrider-3d.io/
antonioguadian45739
antonioguadian45739 posted this 26 September 2025
Uf, totalmente de acuerdo, Themler se vuelve lentísimo cuando intento cambiar varias cosas a la vez 😅. Terminé buscando herramientas como https://es.apkshark.io/ para probar otras opciones más rápidas… ¿tú has encontrado alguna que no se cuelgue tanto?
