Virtuemart IMG TAG
rene-meyer
rene-meyer posted this 01 July 2020
I keep getting the message from various SEO tools that my pictures have no ALT text. They are maintained in VM, but are overwritten by Themler?
Do you have a solution?
thank you
I keep getting the message from various SEO tools that my pictures have no ALT text. They are maintained in VM, but are overwritten by Themler? Do you have a solution? thank you
13 Comments
Support Team posted this 02 July 2020
Hello Rene,
Themler has ALT tag field for all images inserted as content part via Themler, but not for products images.
Do you mean product images?
Hello Rene, Themler has ALT tag field for all images inserted as content part via Themler, but not for products images. Do you mean product images? Gina Themler Support
rene-meyer
rene-meyer posted this 03 July 2020
Yes I mean the old text in the products.
They are not issued, although I maintain them.
Greetings
Yes I mean the old text in the products. They are not issued, although I maintain them. Greetings
Support Team posted this 03 July 2020
Does this text (alt tags) stay on the site when you switch theme from Themler's to any other standard Joomla theme?
Does this text (alt tags) stay on the site when you switch theme from Themler's to any other standard Joomla theme? Gina
rene-meyer
I have now taken a closer look at the code in the rendered page.
It could be related to the Cloudzoom because the problem only occurs in the product details page. The problem does not exist in the product category page.
See here:
<div class="bd-layoutcolumn-64 bd-column"><div class=bd-vertical-align-wrapper><div class=" bd-productimage-6 "><div class=zoom-container> <a class=zoom rel=thumbnails href=https://www.nessetalreisen.de/images/stories/virtuemart/product/Vogtland_Weihnachtsmarkt_2020.jpg> <img width=260 height=260 class=" bd-imagestyles-207" src=https://www.nessetalreisen.de/images/stories/virtuemart/product/Vogtland_Weihnachtsmarkt_2020.jpg /> </a> </div></div><div class=" bd-imagethumbnails-1 carousel slide adjust-slides  "><div class=carousel-inner style="width: 20%;margin: 0 auto;"><div class="item active"> <a class=" bd-productimage-7" style=width:100% rel="smallImage: 'https://www.nessetalreisen.de/images/stories/virtuemart/product/Vogtland_Weihnachtsmarkt_2020.jpg'" href=https://www.nessetalreisen.de/images/stories/virtuemart/product/Vogtland_Weihnachtsmarkt_2020.jpg> <img class=" bd-imagestyles" src=/images/stories/virtuemart/product/resized/Vogtland_Weihnachtsmarkt_2020_300x0.jpg /> </a> </div></div></div></div>
Hello, I have now taken a closer look at the code in the rendered page. It could be related to the Cloudzoom because the problem only occurs in the product details page. The problem does not exist in the product category page. See here: <div class="bd-layoutcolumn-64 bd-column"><div class=bd-vertical-align-wrapper><div class=" bd-productimage-6 "><div class=zoom-container> <a class=zoom rel=thumbnails href=https://www.nessetalreisen.de/images/stories/virtuemart/product/Vogtland_Weihnachtsmarkt_2020.jpg> <img width=260 height=260 class=" bd-imagestyles-207" src=https://www.nessetalreisen.de/images/stories/virtuemart/product/Vogtland_Weihnachtsmarkt_2020.jpg /> </a> </div></div><div class=" bd-imagethumbnails-1 carousel slide adjust-slides "><div class=carousel-inner style="width: 20%;margin: 0 auto;"><div class="item active"> <a class=" bd-productimage-7" style=width:100% rel="smallImage: 'https://www.nessetalreisen.de/images/stories/virtuemart/product/Vogtland_Weihnachtsmarkt_2020.jpg'" href=https://www.nessetalreisen.de/images/stories/virtuemart/product/Vogtland_Weihnachtsmarkt_2020.jpg> <img class=" bd-imagestyles" src=/images/stories/virtuemart/product/resized/Vogtland_Weihnachtsmarkt_2020_300x0.jpg /> </a> </div></div></div></div> Thanks
rene-meyer
rene-meyer posted this 04 July 2020
Deactivating / deleting the Cloudzoom was unfortunately unsuccessful.
rene-meyer
rene-meyer posted this 09 July 2020
Could you help me, please?
Here the link:
Could you help me, please? Here the link: [www.nessetalreisen.de][1] [1]: http://www.nessetalreisen.de
Виктор
Виктор posted this 15 April 2021
Здравствуйте, у меня тоже, на сайте Joomla 3.9.26 Virtuemart 3.8.8, на странице категории товаров, название картинки товара (alt есть), на странице товара, название картинки (alt нет).
Переключая на стандартный шаблон vmbeez3, на странице товара, название картинки товара (alt есть).
Присоединяюсь к этой теме, надо поправить!
Здравствуйте, у меня тоже, на сайте Joomla 3.9.26 Virtuemart 3.8.8, на странице категории товаров, название картинки товара (alt есть), **на странице товара, название картинки (alt нет).** Переключая на стандартный шаблон vmbeez3, на странице товара, название картинки товара (alt есть). Присоединяюсь к этой теме, надо поправить!
Support Team posted this 22 April 2021
Hello Rene and Viktor,
We assume that showing Product Image subtitle can be helpful in your case. Please open Insert >> CMS Code and add this code:
<?php
echo $product->images[0]->file_description;
Hello Rene and Viktor, We assume that showing Product Image subtitle can be helpful in your case. Please open Insert >> CMS Code and add this code: <?php echo $product->images[0]->file_description; ?> Sincerely, Nettie
Виктор
Виктор posted this 24 April 2021
Здравствуйте, у меня Joomla 3.9.26 Virtuemart 3.8.8, внес данный код в шаблон >>CMS Code, сайт выдает ошибку:
 0 - syntax error, unexpected '<', expecting end of file.
Спасибо Нетти, но это не работает.
Здравствуйте, у меня Joomla 3.9.26 Virtuemart 3.8.8, внес данный код в шаблон >>CMS Code, сайт выдает ошибку: 0 - syntax error, unexpected '<', expecting end of file. Спасибо Нетти, но это не работает.
Support Team posted this 07 May 2021
Здравствуйте, Виктор,
CMS Code нужно разместить именно на контроле Product Details рядом с Product Image. На нашей стороне получилось. Правда, выяснилось, что если для какого-то товара используются Related Products, то при их отображении на карточке товара подпись дублируется.
Здравствуйте, Виктор, CMS Code нужно разместить именно на контроле Product Details рядом с Product Image. На нашей стороне получилось. Правда, выяснилось, что если для какого-то товара используются Related Products, то при их отображении на карточке товара подпись дублируется. Sincerely, Nettie
Виктор
Виктор posted this 08 May 2021
Странное, у меня поработало, и опять не показывает.
Abbas Khan
Abbas Khan posted this 09 September 2025
Eco-Friendly and Sustainable Learning Toys Another remarkable shift in 2025 is the increasing demand for eco-friendly and sustainable learning toys. Parents are not only concerned about their children’s education but also about the health of the planet they will inherit. As a result, toy companies are designing products made from recycled, biodegradable, or responsibly sourced materials like bamboo, organic cotton, or non-toxic plastics. These Building Toys go beyond being safe for the environment—they also serve as educational tools to teach children about sustainability.
Eco-Friendly and Sustainable Learning Toys Another remarkable shift in 2025 is the increasing demand for eco-friendly and sustainable learning toys. Parents are not only concerned about their children’s education but also about the health of the planet they will inherit. As a result, toy companies are designing products made from recycled, biodegradable, or responsibly sourced materials like bamboo, organic cotton, or non-toxic plastics. These **[Building Toys][1]** go beyond being safe for the environment—they also serve as educational tools to teach children about sustainability. [1]: https://nextgames.store/collections/building-toys
chinahousehold
chinahousehold posted this 12 December 2025
https://www.hssolar.cn/news-26.html
https://www.foriio.com/works/2078174
https://www.foriio.com/works/2078175
https://etextpad.com/tscigwmexg
https://etextpad.com/91osdw5joh
http://scenarch.com/scenarios/4082
https://japaneseclass.jp/notes/open/107638
https://bothbest.amebaownd.com/posts/58262367
https://bothbest.amebaownd.com/posts/58258603
https://mypaper.pchome.com.tw/bothbest/post/1382380192
https://writexo.com/share/a3163411c1dc
https://karyakarsa.com/bothbest/how-china-bamboo-tradition-shapes-modern-flooring-excellence
https://www.yinai.com.cn/quality-control-in-china-bamboo-manufacturing/
https://karyakarsa.com/chinabamboo/info
https://karyakarsa.com/chinabamboo/bamboo-flooring-a-sustainable-luxury-for-homes-and-businesses
https://bothbestbambooflooring.tawk.help/article/the-heritage-material-reinvented-for-modern-flooring-needs
https://kisanlink.com/forums/discussion/general-discussion/the-high-stability-choice-for-humid-or-changing-climates
https://bothbest.tistory.com/entry/Why-Bamboo-Flooring-Offers-the-Best-Balance-of-Style-and-Durability
https://www.theconsumersfeedback.com/guestpost/elevate-your-home-decor-with-vertical-bamboo-flooring-tips-and-tricks
https://www.hssolar.cn/news-26.html https://www.foriio.com/works/2078174 https://www.foriio.com/works/2078175 https://etextpad.com/tscigwmexg https://etextpad.com/91osdw5joh http://scenarch.com/scenarios/4082 https://japaneseclass.jp/notes/open/107638 https://bothbest.amebaownd.com/posts/58262367 https://bothbest.amebaownd.com/posts/58258603 https://mypaper.pchome.com.tw/bothbest/post/1382380192 https://writexo.com/share/a3163411c1dc https://karyakarsa.com/bothbest/how-china-bamboo-tradition-shapes-modern-flooring-excellence https://www.yinai.com.cn/quality-control-in-china-bamboo-manufacturing/ https://karyakarsa.com/chinabamboo/info https://karyakarsa.com/chinabamboo/bamboo-flooring-a-sustainable-luxury-for-homes-and-businesses https://bothbestbambooflooring.tawk.help/article/the-heritage-material-reinvented-for-modern-flooring-needs https://kisanlink.com/forums/discussion/general-discussion/the-high-stability-choice-for-humid-or-changing-climates https://bothbest.tistory.com/entry/Why-Bamboo-Flooring-Offers-the-Best-Balance-of-Style-and-Durability https://www.theconsumersfeedback.com/guestpost/elevate-your-home-decor-with-vertical-bamboo-flooring-tips-and-tricks
