i have a problem, i need the availibility native function of Virtuemart in my template.
This function work fine with Protostar template, but not with Themler.
What i did is try to copy/past the code i have in the com_virtuemart/sublayouts/stockhandle.php in a cms control in my product detail view in Themler.
The normal use is when a product is out of stock, that show an image with the shipping delay. This image can be configured in the global VM config or overrided per product.
So with my test, the information still showed, in all products, even if in stock, and the override function dosent work anymore.
Can you help me make it functionnal ?
Hello, i have a problem, i need the availibility native function of Virtuemart in my template. This function work fine with Protostar template, but not with Themler. What i did is try to copy/past the code i have in the com_virtuemart/sublayouts/stockhandle.php in a cms control in my product detail view in Themler. The normal use is when a product is out of stock, that show an image with the shipping delay. This image can be configured in the global VM config or overrided per product. So with my test, the information still showed, in all products, even if in stock, and the override function dosent work anymore. Can you help me make it functionnal ?
