Guttenberg compatibility
SionCO
SionCO posted this 14 July 2020
There is some possibility that Themler is compatible with Guttenberg, since I have tried and most of the blocks do not really work well, I think Guttenberg is the future of Wordpress and Themler, if it is a project that is still alive it should work on it.
One of the most basic problems that I found is that when I work with Themler's template it doesn't allow me to put a block to full screen, while if I work with Twenty Twenty, they allow me a series of great options like having a slightly wider block. than the rest of the content or having it on full screen, even having a full-width background image or color even if the content remains in the middle.
In the attached image you can see the difference in the alignment when using one or another template, the one on the right is Themler with fewer options, this happens in all the blocks. Can this be solved? I already tried putting the section to full width but this affects all the content and I only want one of the blocks to be full width.
There is some possibility that Themler is compatible with Guttenberg, since I have tried and most of the blocks do not really work well, I think Guttenberg is the future of Wordpress and Themler, if it is a project that is still alive it should work on it. One of the most basic problems that I found is that when I work with Themler's template it doesn't allow me to put a block to full screen, while if I work with Twenty Twenty, they allow me a series of great options like having a slightly wider block. than the rest of the content or having it on full screen, even having a full-width background image or color even if the content remains in the middle. In the attached image you can see the difference in the alignment when using one or another template, the one on the right is Themler with fewer options, this happens in all the blocks. Can this be solved? I already tried putting the section to full width but this affects all the content and I only want one of the blocks to be full width.
Support Team posted this 15 July 2020
Hello Sion,
The issues are reported to the developers.
Make sure you have Themler 502 though. (it is beta release).
Themler support
Hello Sion, The issues are reported to the developers. Make sure you have Themler 502 though. (it is beta release). Gina Themler support
SionCO
SionCO posted this 15 July 2020
Thanks, as I see I have Themler v.499 that I downloaded it from your page last week and the update button does not appear, how can I go to 502?
By the way on the updates site is it reported until 466 https://answers.themler.io/categories/3916/feature-updates?
Thanks, as I see I have Themler v.499 that I downloaded it from your page last week and the update button does not appear, how can I go to 502? By the way on the updates site is it reported until 466 https://answers.themler.io/categories/3916/feature-updates?
Support Team posted this 16 July 2020
Since 466 there were only Beta Updates, not included in the release notes, unfortunately.
You need to go to your account on our site and enable GET BETA UPDATES option there:
Since 466 there were only Beta Updates, not included in the release notes, unfortunately. You need to go to your account on our site and enable GET BETA UPDATES option there: !get-beta-updates.png! Gina Themler Support
SionCO
SionCO posted this 18 July 2020
Ok, I already updated it but the option to set the block to full width still does not appear, that is, you still need to adjust the compatibility with Guttenberg.
Support Team posted this 19 July 2020
Thank you for the update. This is reported to the developers.
Thank you for the update. This is reported to the developers. Gina Themler Support
