PHP 7.3 error
johann9
johann9 posted this 15 July 2020
Hi there, I saw that there are a number of related issues when people tried to edit Themler in php 7.2. This seemed to have been fixed, but as PHP 7.2 are coming to an end, I tried a fresh installation on PHP 7.3 and the latest Themler update, but this error has returned. It works fine in PHP 7.2,
[PHP_ERROR]{"message":"\n\nOS: Linux dedi575.jnb2.host-h.net 4.9.0-11-amd64 #1 SMP Debian 4.9.189-3+deb9u1 (2019-09-20) x86_64\nPHP: 7.3.19-1+0~20200612.60+debian9~1.gbp6c8fe1\nerror handler: strpos():.....
What I have tried; Cleared the website's cache, removed the history in my browser. I have also installed the desktop version and exported the theme from there to my website. No luck.
Is there a possible fix?
Thanks, Johann
Hi there, I saw that there are a number of related issues when people tried to edit Themler in php 7.2. This seemed to have been fixed, but as PHP 7.2 are coming to an end, I tried a fresh installation on PHP 7.3 and the latest Themler update, but this error has returned. It works fine in PHP 7.2, [PHP_ERROR]{"message":"\n\nOS: Linux dedi575.jnb2.host-h.net 4.9.0-11-amd64 #1 SMP Debian 4.9.189-3+deb9u1 (2019-09-20) x86_64\nPHP: 7.3.19-1+0~20200612.60+debian9~1.gbp6c8fe1\nerror handler: strpos():..... *What I have tried*; Cleared the website's cache, removed the history in my browser. I have also installed the desktop version and exported the theme from there to my website. No luck. Is there a possible fix? Thanks, Johann
11 Comments
Support Team posted this 16 July 2020
Could you please update Themler to v505?
In order to open the theme for the update you need to either downgrade PHP version or copy theme folder via FTP from the server, open it with Themler Desktop and update there.
Hello, Could you please update Themler to v505? In order to open the theme for the update you need to either downgrade PHP version or copy theme folder via FTP from the server, open it with Themler Desktop and update there. Gina Themler Support
johann9
johann9 posted this 17 July 2020
Hi Gina, I updated the theme to v505, but once I select php7.3 again, the same error returns. I also tried a fresh theme install
Thanks!
Johann
Hi Gina, I updated the theme to v505, but once I select php7.3 again, the same error returns. I also tried a fresh theme install Thanks! Johann
Support Team posted this 17 July 2020
Johann,
This is weird since version 505 has the fix for this exact error.
Could you please try to clear the cache on the site. You can also try using PHP 7.4.
If the error is still there, please, provide temporary access to the site.
Themler support
Johann, This is weird since version 505 has the fix for this exact error. Could you please try to clear the cache on the site. You can also try using PHP 7.4. If the error is still there, please, provide temporary access to the site. Gina Themler support
johann9
Cleared cache as requested as well, but the problem persists. I do not have access to php7.4 yet, only 7.3 and 7.2
Here are the log in details as requested
http://bloemvillage.co.za/2020/administrator
UN
adminjQt88c6c
PW
pQRXhMqnjQt88c6c
Thanks, Johann
Cleared cache as requested as well, but the problem persists. I do not have access to php7.4 yet, only 7.3 and 7.2 Here are the log in details as requested http://bloemvillage.co.za/2020/administrator UN adminjQt88c6c PW pQRXhMqnjQt88c6c Thanks, Johann
Support Team posted this 19 July 2020
Johann,
Could you please switch to OFF Cache under Globar Configuration and disable 3rd party plugins? (start with firewall plugin, box builder).
Check if any of those are conflicting with Themler.
Johann, Could you please switch to OFF Cache under Globar Configuration and disable 3rd party plugins? (start with firewall plugin, box builder). Check if any of those are conflicting with Themler. Gina Themler Support
johann9
johann9 posted this 20 July 2020
I tried your suggestion, but that did not solve the problem. Then I decided to do a fresh install and only install Themler. I updated the template to v505, then acticvated php7.3 and that again popped an error.
If you want to have a look, here are the user details :
http://bloem-online.co.za/joomla_default/administrator
username and password:
adminpSBwnb7W
9mJVaUpSBwnb7Wna2YNF
Thanks, Johann
I tried your suggestion, but that did not solve the problem. Then I decided to do a fresh install and only install Themler. I updated the template to v505, then acticvated php7.3 and that again popped an error. If you want to have a look, here are the user details : http://bloem-online.co.za/joomla_default/administrator username and password: adminpSBwnb7W 9mJVaUpSBwnb7Wna2YNF Thanks, Johann
Support Team posted this 20 July 2020
Could you please share FTP access as well?
Themler support
Could you please share FTP access as well? Gina Themler support
johann9
FTP server : 129.232.138.10
bloemwatkb_0
QUmq8mzMver9n5N1JsF8
FTP server : 129.232.138.10 bloemwatkb_0 QUmq8mzMver9n5N1JsF8
johann9
johann9 posted this 30 July 2020
Any luck here?
Any luck here?
alexarafatonline
alexarafatonline posted this 03 July 2025
I had the same issue with Themler on PHP 7.3—super frustrating! It worked fine on 7.2, but the error popped up after upgrading. Have you tried reaching out to their support? Sometimes they release patches for newer PHP versions.
On a different note, if you're into Roblox scripting, the Delta Executor latest version is a game-changer. Smooth performance, no complicated setup, and works great on Windows & Android. The devs are even working on iOS/Mac versions, so hopefully, it’ll be available soon for everyone. Just make sure to grab it from the official site to avoid sketchy downloads!
I had the same issue with Themler on PHP 7.3—super frustrating! It worked fine on 7.2, but the error popped up after upgrading. Have you tried reaching out to their support? Sometimes they release patches for newer PHP versions. On a different note, if you're into Roblox scripting, the [Delta Executor latest version][1] is a game-changer. Smooth performance, no complicated setup, and works great on Windows & Android. The devs are even working on iOS/Mac versions, so hopefully, it’ll be available soon for everyone. Just make sure to grab it from the official site to avoid sketchy downloads! [1]: https://deltaexecutor-ph.com/
w818656
w818656 posted this 13 August 2025
Hi! The error you’re experiencing might be caused by outdated tools or compatibility issues with PHP. Similar problems often happen in Roblox when users run an older version of the executor, which can lead to upgrade or runtime errors. To avoid interruptions and keep your games running smoothly, it’s important to always use the latest version. If you’re facing issues like this, you can check out guidance on roblox error and find steps to fix it. Updating your executor usually resolves most upgrade and compatibility problems quickly. Taking this simple step ensures you can continue enjoying your games without unexpected crashes or errors.
Hi! The error you’re experiencing might be caused by outdated tools or compatibility issues with PHP. Similar problems often happen in Roblox when users run an older version of the executor, which can lead to upgrade or runtime errors. To avoid interruptions and keep your games running smoothly, it’s important to always use the latest version. If you’re facing issues like this, you can check out guidance on [roblox error][1] and find steps to fix it. Updating your executor usually resolves most upgrade and compatibility problems quickly. Taking this simple step ensures you can continue enjoying your games without unexpected crashes or errors. [1]: https://deltaexecutordl.com/fix-roblox-upgrade-error/
