The issue where the mobile menu hamburger icon does not open on the first click could be caused by a couple things:
A JavaScript conflict or error that is preventing the click event from properly toggling the menu open/closed on first click. I would check the JavaScript console for any errors and debug why the click handler is not working right away.
An issue with click event propagation on the hamburger icon. Maybe the click is getting caught/stopped by another element, preventing the menu toggle. You can try adjusting the z-index or containment of elements.
A CSS problem where the actual menu container is hidden/collapsed on first load, so clicking the hamburger icon tries to open it but it has display:none initially. You may need to override default styles.
Some things to try:
Test if the click event is firing on the hamburger button by adding a console.log on click. See if event reaches icon.
Simplify any animated transitions or complex JavaScript temporarily to debug.
Check if clicking menu directly would work to rule out JS issues.
View mobile site emulation before any user scrolling to rule out positional/layout issues.
Validate markup semantics and check for missing container elements.
Focus debugging efforts on the hamburger icon and the menu toggle functionality specifically to identify what causes the first-click failure. Let me know if any specific details about the implementation would help troubleshoot further!
Some things to try:
