Themler doesn't work
armando.gobbi2
armando.gobbi2 posted this 26 July 2020
since this afternoon themler doesn't work on Joomla.
when I click on "edit template" (img attached) themler doesn't run and remains a blank page.
what's the problem???!!!!
Hi, since this afternoon themler doesn't work on Joomla. when I click on "edit template" (img attached) themler doesn't run and remains a blank page. what's the problem???!!!!
33 Comments
Support Team posted this 27 July 2020
We have fixed the issue, please try now. You may need to clear cache if the issue is still present and then try again.
Hello, We have fixed the issue, please try now. You may need to clear cache if the issue is still present and then try again. Sincerely, Nettie
frederic11
frederic11 posted this 27 July 2020
Dosent work, even if i clear the cache
vis
vis posted this 27 July 2020
Still doesn't work. Even clearing the cache. Please fix it asap!!
We have made another fix less than hour ago, should be working.
We have made another fix less than hour ago, should be working. Gina Themler Support
frederic11
It work now for me.
It work now for me. Thank you
apps5
apps5 posted this 27 July 2020
Testet on one Site, worked now again...
vis
It works!! Thank you!
BeauSol Mediasolution
BeauSol Mediasolution posted this 27 July 2020
Thank you!!!! It works...
web750
web750 posted this 27 July 2020
I can confirm 2 sites on Woocommerce are working with Themler after clearing deep cache
Thank You
I can confirm 2 sites on Woocommerce are working with Themler after clearing deep cache Thank You
Support Team posted this 28 July 2020
Thank you all for your feedback!
Themler team
Thank you all for your feedback! Sincerely, Themler team
FrenchSpy
FrenchSpy posted this 29 July 2020
Thank!
Thank!
libialapaugh
libialapaugh posted this 05 August 2020
This issue is happening on Html also. Not loading
Support Team posted this 06 August 2020
We have answered in a separate topic.
Hello, We have answered in a separate topic. Sincerely, Nettie
