margin between container and image fload right
bob52
bob52 posted this 13 August 2015
Hi there
i work with the default heme.
I notice two things i cant find:
1)
if i put in a image in a container the container gets wider than the rest of the content.
When i put a image in it and float it right it stops correct on the alligning of the rest of the site but because the container becomes bigger it does not look correct.
see image 1.
enter image description here
the same space is there at the slider
How do i get rid of those strange margins?
Thank jou
Hi there i work with the default heme. I notice two things i cant find: 1) if i put in a image in a container the container gets wider than the rest of the content. When i put a image in it and float it right it stops correct on the alligning of the rest of the site but because the container becomes bigger it does not look correct. see image 1. ![enter image description here][1] the same space is there at the slider ![enter image description here][2] How do i get rid of those strange margins? Thank jou [1]: http://www.stinkfinger.nl/1.jpg [2]: http://stinkfinger.nl/2.jpg
bob52
I Found it!
At Settings -> grid padding
I Found it! At Settings -> grid padding
Stagger Lee posted this 13 August 2015
Dont do it. There are other ways to achieve it. You just ruined spacing between blocks in Blog/Archive template if you show 2-3-4 Posts in one row.
If you try to compensate it with padding/margin you will have it hard because Bootstrap doesnt work anymore as it should.
I will make one test to confirm all this, but I am pretty sure it is so.
Dont do it. There are other ways to achieve it. You just ruined spacing between blocks in Blog/Archive template if you show 2-3-4 Posts in one row. If you try to compensate it with padding/margin you will have it hard because Bootstrap doesnt work anymore as it should. I will make one test to confirm all this, but I am pretty sure it is so.
OK tested, I am sorry for mistake. It is "Gutter width" option you should not touch.
Support Team posted this 14 August 2015
Hi guys,
Yep, the Grid padding is a correct option.
Let us know if you have any further questions.
Ivan
Hi guys, Yep, the **Grid padding** is a correct option. Let us know if you have any further questions. Thanks, Ivan
