HTML is not loading
libialapaugh
libialapaugh posted this 28 July 2020
I open the application and select HtML Pages and it does not load.
Support Team posted this 29 July 2020
7. Download latest version of Themler for Windows from themler.io, install it and try to start with Themler for HTML and create a theme.
Hello, Please follow the steps below: 1. Backup all theme folders somewhere on your computer if there are any. The path is shown in the Theme Management screen after selecting some CMS, for example, `C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\wordpress`. 2. Uninstall Themler completely and also check the box for "Remove all CMS content". 3. Check if the following folders are still present: C:\Program Files (x86)\Themler C:\ProgramData\Themler 4. If they exist, remove them. 5. Reboot the machine after uninstalling Themler, so that all Themler services are removed for sure. 6. Temporarily disable antivirus and firewall. 7. Download latest version of Themler for Windows from themler.io, install it and try to start with Themler for HTML and create a theme. Please let us know the result. Sincerely, Nettie
libialapaugh
libialapaugh posted this 05 August 2020
I did this and it worked the first time but after that is did not load again.
Support Team posted this 06 August 2020
It can happen that antivirus or firewall are not disabled completely even if stopping them and are blocking/removing necessary files.
Please try to add the following folder to your antivirus/firewall white list:
C:\Program Files (x86)\Themler\
Please also add the website *.themler.io to exception list as well as ''themler.com" and "*.billiondigital.com". If it is not possible, please try adding cstatic.billiondigital.com and cstatic.themler.io.
After this please repeat the steps above.
Hello, It can happen that antivirus or firewall are not disabled completely even if stopping them and are blocking/removing necessary files. Please try to add the following folder to your antivirus/firewall white list: C:\Program Files (x86)\Themler\ C:\ProgramData\Themler Please also add the website `*.themler.io` to exception list as well as ''themler.com" and "*.billiondigital.com". If it is not possible, please try adding `cstatic.billiondigital.com` and `cstatic.themler.io`. After this please repeat the steps above. Sincerely, Nettie
jkj2
jkj2 posted this 07 October 2025
How do you install themler on mac?
