I have detected an incompatibility with the latest version of Wordpress 5.5, I am working with Themler v.505 and the widgets do not work, they appear blocked and cannot be edited or modified, the widget areas are not displayed.
When I change the template to twenty twenty, GeneratePress or any other, everything works fine, do you have a solution for this? it is something serious that makes the tool useless.
VIDEO SAMPLE: https://onedrive.live.com/?cid=BEC25B067F680D69&id=BEC25B067F680D69%211972&parId=BEC25B067F680D69%21144&o=OneUp
NOTE: In plugins only "Themler core" is installed and it is a new Wordpress installation.
I have detected an incompatibility with the latest version of **Wordpress 5.5**, I am working with **Themler v.505** and the widgets do not work, they appear blocked and cannot be edited or modified, the widget areas are not displayed. When I change the template to twenty twenty, GeneratePress or any other, everything works fine, do you have a solution for this? it is something serious that makes the tool useless. VIDEO SAMPLE: https://onedrive.live.com/?cid=BEC25B067F680D69&id=BEC25B067F680D69%211972&parId=BEC25B067F680D69%21144&o=OneUp **NOTE:** In plugins only "Themler core" is installed and it is a new Wordpress installation.
