Comments are no longer displayed in Wordpress
reiner6
reiner6 posted this 24 August 2020
On our site, no comments have been displayed in the frontend for 1-2 weeks.
Before that it worked without any problems.
Now only something like this is displayed.
10 answers to day trip Taubertal n. Rothenburg o / T
But the comments are missing.
Nothing was changed in the settings.
Can an update be responsible?
https://www.chopper-motorrad.de/?event=tagesausfahrt-taubertal-n-rothenburg-o-t-u-besuch-biergarten-baumhaus-in-rennhofen
Hello, On our site, no comments have been displayed in the frontend for 1-2 weeks. Before that it worked without any problems. Now only something like this is displayed. **10 answers to day trip Taubertal n. Rothenburg o / T** But the comments are missing. Nothing was changed in the settings. Can an update be responsible? https://www.chopper-motorrad.de/?event=tagesausfahrt-taubertal-n-rothenburg-o-t-u-besuch-biergarten-baumhaus-in-rennhofen
42 Comments
Support Team posted this 24 August 2020
We are sorry for the issue. Our developers are working at fixing it and we will let you know when the fix is ready.
Hello, We are sorry for the issue. Our developers are working at fixing it and we will let you know when the fix is ready. Sincerely, Nettie
braserox
braserox posted this 26 August 2020
Same issue for me, any update concerning this issue?
Kevin
Hello, Same issue for me, any update concerning this issue? Regards Kevin
Support Team posted this 26 August 2020
Hello Kevin,
Sorry, no update yet, we will keep you posted ASAP.
Hello Kevin, Sorry, no update yet, we will keep you posted ASAP. Sincerely, Nettie
wouter.rommel
wouter.rommel posted this 27 August 2020
Same problem here... hope this gets fixed asap...
thanks,
Kind regards,
Wouter
Hello, Same problem here... hope this gets fixed asap... thanks, Kind regards, Wouter
info2021
info2021 posted this 28 August 2020
Hello Themler,
Same problem here... Any updates?
Kind regards,
Jos
Hello Themler, Same problem here... Any updates? Kind regards, Jos
Eric-P
Eric-P posted this 30 August 2020
Good morning all,
I have the same problem, it seems that this is not fixed, the comments exist in Wordpress but can no longer be displayed.
Good morning all, I have the same problem, it seems that this is not fixed, the comments exist in Wordpress but can no longer be displayed.
Support Team posted this 31 August 2020
Please, update your theme version to Themler v511 (Beta).
Hello, Please, update your theme version to Themler v511 (Beta). Gina Themler Support
reiner6
reiner6 posted this 31 August 2020
Is there a hack I can build directly into the existing source code?
I can't do everything all over again.
Which file has to be adjusted?
Is there a hack I can build directly into the existing source code? I can't do everything all over again. Which file has to be adjusted?
smith8395john
smith8395john posted this 31 August 2020
Same issue
Same issue
Unfortunately, there is no easy workaround for this issue. Several files were updated, thus, it is advised to update the theme in Themler.
It is inevitable process to update themes whenever new CMS version is out with some changes in basic code functions. WordPress 5.5 have changes its usage of scripts.
Unfortunately, there is no easy workaround for this issue. Several files were updated, thus, it is advised to update the theme in Themler. It is inevitable process to update themes whenever new CMS version is out with some changes in basic code functions. WordPress 5.5 have changes its usage of scripts. Gina Themler Support
reiner6
This is not good.
Unfortunately, the file can no longer be loaded in Themler.
There comes this error in the appendix.
Import failed
Unfortunately only WordPress Themler themes are supported
This is not good. Unfortunately, the file can no longer be loaded in Themler. There comes this error in the appendix. **Import failed Unfortunately only WordPress Themler themes are supported**
Please try this way:
1. Copy the theme from the website via FTP
2. Zip-compress it
3. Import in Themler desktop
4. Update it to the latest Themler version. You may need to update Beta update notifications in your profile for this.
5. Export the theme under a different name
6. Install the theme in your CMS.
Hello, Please try this way: 1. Copy the theme from the website via FTP 2. Zip-compress it 3. Import in Themler desktop 4. Update it to the latest Themler version. You may need to update Beta update notifications in your profile for this. 5. Export the theme under a different name 6. Install the theme in your CMS. Sincerely, Nettie
Stagger Lee posted this 07 September 2020
Make some post about manual changes. It is not fair for customers without a licence old websites stop to working.
reiner6
reiner6 posted this 11 September 2020
I totally agree with you
> Make some post about manual changes. It is not fair for customers without a licence old websites stop to working. I totally agree with you
Support Team posted this 11 September 2020
Try adding this code to the end of the "function.php" of your theme :
function wp51082_restore_empty_comment_type_on_frontend( $comment ) {
if ( ! is_admin() && 'comment' === $comment->comment_type ) {
$comment->comment_type = '';
return $comment;
add_filter( 'get_comment', 'wp51082_restore_empty_comment_type_on_frontend' );
Try adding this code to the end of the "function.php" of your theme : function wp51082_restore_empty_comment_type_on_frontend( $comment ) { if ( ! is_admin() && 'comment' === $comment->comment_type ) { $comment->comment_type = ''; } return $comment; } add_filter( 'get_comment', 'wp51082_restore_empty_comment_type_on_frontend' ); Gina
Stagger Lee posted this 11 September 2020
Showed comments HTML wrapper and classes but no comments.
Inside my custom functions.php plugin it shows all comments. Something with priority.
ZZZuper, thank you.
Showed comments HTML wrapper and classes but no comments. Inside my custom functions.php plugin it shows all comments. Something with priority. ZZZuper, thank you.
reiner6
Thanks, that works great!
jobssfair1
jobssfair1 posted this 19 September 2020
[BOI][1] Oh I had the Same Issue, but after [UP][2]dating theme my Issue resolved
petercoffin80
petercoffin80 posted this 19 September 2020
Which theme are you using? May be it is nulled, that's why it is an error.
wouter.rommel
wouter.rommel posted this 26 September 2020
return $comment;
That worked fine. Thanks,
W
> Try adding this code to the end of the "function.php" of your theme : > > function wp51082_restore_empty_comment_type_on_frontend( $comment ) { > > if ( ! is_admin() && 'comment' === $comment->comment_type ) { > > $comment->comment_type = ''; > > } > > > > return $comment; > > } > > add_filter( 'get_comment', 'wp51082_restore_empty_comment_type_on_frontend' ); > > Gina That worked fine. Thanks, W
