update is not available
marcin_tomas
marcin_tomas posted this 04 September 2020
I used themler and Joomla. In my theme I don't have possibility to make updates of themler.
Now I have version 355
Hello, I used themler and Joomla. In my theme I don't have possibility to make updates of themler. Now I have version 355
Support Team posted this 04 September 2020
The theme is rather old, so there can be indeed issues with updating, Still it can be helpful, to follow these steps:
  1. Open Themler Desktop
  2. Open your theme
  3. Make its copy under different (slightly) name via File -> Make a copy as
  4. Close Themler Desktop
  5. Open Themler desktop
  6. Select your CMS (Joomla in this case)
  7. Fine the copy of the theme in the list of themes there you have
  8. Open it and it should start updating, or at least should be opened with the red Update button on top available
Hello, The theme is rather old, so there can be indeed issues with updating, Still it can be helpful, to follow these steps: 1. Open Themler Desktop 2. Open your theme 3. Make its copy under different (slightly) name via File -> Make a copy as 4. Close Themler Desktop 5. Open Themler desktop 6. Select your CMS (Joomla in this case) 7. Fine the copy of the theme in the list of themes there you have 8. Open it and it should start updating, or at least should be opened with the red Update button on top available Sincerely, Nettie
marcin_tomas
thanks for answer,
How can I donwload Themler Desktop? Link doesn't work: https://getthemler.com/Themler2.1.0.441.e3ce2.exe
Hello, thanks for answer, How can I donwload Themler Desktop? Link doesn't work: https://getthemler.com/Themler2.1.0.441.e3ce2.exe
Sorry, we will fix the issue ASAP and let you know.
Hello, Sorry, we will fix the issue ASAP and let you know. Sincerely, Nettie
The issue is fixed, the download link should work now.
Hello, The issue is fixed, the download link should work now. Sincerely, Nettie
