Can not update
rein
rein posted this 2 weeks ago
Hey, when I click 'edit template' in the joomla backend, I get a popup with:
{"result":"done","version":"487"}[PHP_ERROR]{"message":"\n\nOS: Linux host.123-hosting-server.net 2.6.32-042stab141.3 #1 SMP Fri Nov 15 22:45:34 MSK 2019 x86_64\nPHP: 7.4.3\nerror handler: Trying to access array offset on value of type null\nArray\n(\n [errorText] => \n [error] => \n)\n Callstack: \n -> shutdownHandler()\n\n\n","type":"E_NOTICE","file":"/home/rodvision3/domains/rodvisions.nl/public_html/templates/hengelshop/app/classes/Helper.php","line":185}[PHP_ERROR]
Do you have any idea? Kind regards, Rein
Hey, when I click 'edit template' in the joomla backend, I get a popup with: {"result":"done","version":"487"}[PHP_ERROR]{"message":"\n\nOS: Linux host.123-hosting-server.net 2.6.32-042stab141.3 #1 SMP Fri Nov 15 22:45:34 MSK 2019 x86_64\nPHP: 7.4.3\nerror handler: Trying to access array offset on value of type null\nArray\n(\n [errorText] => \n [error] => \n)\n Callstack: \n -> shutdownHandler()\n\n\n","type":"E_NOTICE","file":"\/home\/rodvision3\/domains\/rodvisions.nl\/public_html\/templates\/hengelshop\/app\/classes\/Helper.php","line":185}[PHP_ERROR] Do you have any idea? Kind regards, Rein
Hello Rein,
You need to update the templates first.
You can either downgrade your PHP version, I assume it is 7.3 or higher?
Or you can open the theme with Themler Desktop, update to version 511 and export.
If you don't have your theme saved on your computer, you can access it on your server via FTP. Just copy the theme folder from there, zip it and open with desktop version.
Hello Rein, You need to update the templates first. You can either downgrade your PHP version, I assume it is 7.3 or higher? Or you can open the theme with Themler Desktop, update to version 511 and export. If you don't have your theme saved on your computer, you can access it on your server via FTP. Just copy the theme folder from there, zip it and open with desktop version. Gina Themler Support
rein
Gina, thank you very much, it works again.
Rein
Gina, thank you very much, it works again. Rein
