I got this message when I wanted to open the Themler Theme in Joomla.
Do you see what's the problem?
Thank you in advance.
Kind regards,
Yvonne Widmer
Kind regards,
Yvonne Widmer
Attached is the text in line 185 of helper.php.
Any idea?
Thank you.
Kind regards,
Yvonne
It means the theme is old for this version of Joomla.
You need to open it with Themler desktop, update to version 511 and re-install to Joomla.
Ok thanks a lot.
Can I export the theme from Joomla to open it afterwards in Desktop Themler as I made a lot of changes in Joomla (Themler) which I had to update manually.
Thank you for your answer.
Best regards,
Yvonne
Hi Gina
Another question. Is it also a problem of PHP upgrade 7.3 to 7.4 or doesn't it matter which version?
Thank you.
Kind regards,
Yvonne Widmer
Hello Gina,
My Hoster put back PHP Version and now it's better.
I still have the message please clear browser cache and second message white screen (?)
I hope that I can open once againg my Theme in Joomla an then upgrade the actual version to a newer Themler version. Is that possible, what do you think?
I had to make a lot of changes on my actuel template of desktop version as I haven't been working on desktop version for a long time.
Thanks for your help.
Kind regards,
Yvonne Widmer
1) PHP 7.3 and 7.4 are supported by Themler v511.
2) In order not to lose what your have already done in bowser based Themler editor (via Joomla), you can access your site via FTP, go to templates folder and copy this theme folder. Zip it and open with Themler desktop.
3) Try step 2 with your current theme, you can also re-name it when exporting next time.
