Hello good day.
My joomla installation is 3.9.21. and PHP 7.3
If I download themler and install it on my joomla everything works fine. I update the plugins and can edit the template without problems. Everything works perfectly with PHP 7.3 and Joomla 3.9.21.
When I install in my joomla the template made with my desktop themler (I work with MAC), I cannot edit the theme from my Joomla. I have two problems.
1- I have a 500 error when I try to install the plugins. This error occurs with PHP 5.3 and PHP 7.3.
2- The theme editor does not work with PHP 7.3. I have tried PHP 5.3 and the editor works fine.
Can you give me a solution?
Hello good day. My joomla installation is 3.9.21. and PHP 7.3 If I download themler and install it on my joomla everything works fine. I update the plugins and can edit the template without problems. Everything works perfectly with PHP 7.3 and Joomla 3.9.21. When I install in my joomla the template made with my desktop themler (I work with MAC), I cannot edit the theme from my Joomla. I have two problems. 1- I have a 500 error when I try to install the plugins. This error occurs with PHP 5.3 and PHP 7.3. 2- The theme editor does not work with PHP 7.3. I have tried PHP 5.3 and the editor works fine. Can you give me a solution?
