Set-Cookie
linuxoid
linuxoid posted this 4 weeks ago
Hi!
How can I remove headers from a template
Set-Cookie: componentType=default; path=/
Set-Cookie: componentType=blog; path=/
Set-Cookie: componentStyle=blog_2; path=/
Hi! How can I remove headers from a template Set-Cookie: componentType=default; path=/ Set-Cookie: componentType=blog; path=/ Set-Cookie: componentStyle=blog_2; path=/
12 Comments
Hello Mike,
Themler doesn't add or control cookies. What template type do you use (Wordpress, Joomla, etc)?
Have you tried disabling all 3rd party plugins?
Themler support
Hello Mike, Themler doesn't add or control cookies. What template type do you use (Wordpress, Joomla, etc)? Have you tried disabling all 3rd party plugins? Gina Themler support
linuxoid
joomla
Hi joomla
I haven't found such headers in exported blank Joomla theme. Could you please disable all cookie related extensions and test again?
You can also test standard Joomla theme to see if those headers still come.
I haven't found such headers in exported blank Joomla theme. Could you please disable all cookie related extensions and test again? You can also test standard Joomla theme to see if those headers still come. Gina Themler Support
linuxoid
linuxoid posted this 3 weeks ago
Hi!
There are no headers on the standard template ...
Checked a 404 error that is not handled by plugins and also got two extra headers:
php 7.1 - 7.3
Set-Cookie: componentType=error404; path=/
grep -r "componentType"
templates/my/component.php: if ($parts[0] == $_COOKIE['componentType'] && isset($_COOKIE['componentStyle']))
templates/my/editor/component.php: if ($parts[0] == $_COOKIE['componentType'] && isset($_COOKIE['componentStyle']))
templates/my/editor/functions.php: setcookie('componentType', $templateType, 0, '/');
templates/my/functions.php: setcookie('componentType', $templateType, 0, '/');
not found anywhere else
Hi! There are no headers on the standard template ... Checked a 404 error that is not handled by plugins and also got two extra headers: php 7.1 - 7.3 Set-Cookie: componentType=default; path=/ Set-Cookie: componentType=error404; path=/ grep -r "componentType" templates/my/component.php: if ($parts[0] == $_COOKIE['componentType'] && isset($_COOKIE['componentStyle'])) templates/my/editor/component.php: if ($parts[0] == $_COOKIE['componentType'] && isset($_COOKIE['componentStyle'])) templates/my/editor/functions.php: setcookie('componentType', $templateType, 0, '/'); templates/my/functions.php: setcookie('componentType', $templateType, 0, '/'); not found anywhere else
linuxoid
php 7.0
Set-Cookie: componentStyle=common; path=/
php 7.0 Set-Cookie: componentType=default; path=/ Set-Cookie: componentStyle=common; path=/
linuxoid
A site where there are no plugins or modules
PHP/7.3.6
A site where there are no plugins or modules PHP/7.3.6 Set-Cookie: componentType=default; path=/ Set-Cookie: componentType=blog; path=/
Could you please attach your theme?
Could you please attach your theme? Gina
linuxoid
Here, so that it is indexed...)I have a lot of them, and they all generate such headers
Unfortunately, your attachment hasn't come through.
I have double-checked default Themler template and checked its files, but couldn't find such header.
We will keep looking, I hope your template would help.
Unfortunately, your attachment hasn't come through. I have double-checked default Themler template and checked its files, but couldn't find such header. We will keep looking, I hope your template would help. Gina
linuxoid
Hi attachment
The only way to remove those lines is to manually edit files that you have already mentioned:
In order to edit them , remove this function:
Themler support
The only way to remove those lines is to manually edit files that you have already mentioned: templates/my/component.php templates/my/editor/component.php templates/my/editor/functions.php templates/my/functions.php In order to edit them , remove this function: !Screenshot-2.png! Gina Themler support
linuxoid
Is Solution
linuxoid posted this 2 weeks ago
Hi!
thanks for the support
Comment out:
/templates/my/functions.php
#       setcookie('componentType', $templateType, 0, '/');
/templates/my/library/Designe/Page.php
#        setcookie('componentStyle', $template, 0, '/');
Hi! thanks for the support Comment out: Set-Cookie: componentType=default; path=/ /templates/my/functions.php # setcookie('componentType', $templateType, 0, '/'); Set-Cookie: componentType=blog; path=/ /templates/my/library/Designe/Page.php # setcookie('componentStyle', $template, 0, '/');
