Menu ruchome zoom
stryjek-www
stryjek-www posted this 6 days ago
Witam jak zrobić podobne ruchome menu zoom jak na tej stronie http://www.sala-orchidea.pl/ chodzi mi o cały pomniejszający się nagłówek i zmianę wyglądu
17 Comments
Support Team posted this 3 days ago
It is possible to do such menu only using custom CSS code. To begin with, you need to place the initial styling for the menu: transparent background, overlapping the header and fixed position.
Then it is necessary to add custom code to change the menu background on scroll and make the header logo smaller. We can help with that.
Hello, It is possible to do such menu only using custom CSS code. To begin with, you need to place the initial styling for the menu: transparent background, overlapping the header and fixed position. Then it is necessary to add custom code to change the menu background on scroll and make the header logo smaller. We can help with that. Gina Themler Support
stryjek-www
stryjek-www posted this 3 days ago
jak to zrobić prosze o pomoc
I can help but I need to work on the actual site.
When it is live with the initial styling of the menu, please, provide the link to it.
Themler support
I can help but I need to work on the actual site. When it is live with the initial styling of the menu, please, provide the link to it. Gina Themler support
stryjek-www
http://salarozany.gpe.pl/
Please, explain the desired behavior?
If you want the menu to be transparent but get white background on scroll, please, make it transparent now, and I will provide the code for the styling on scroll.
Please, explain the desired behavior? If you want the menu to be transparent but get white background on scroll, please, make it transparent now, and I will provide the code for the styling on scroll. Gina
stryjek-www
ok już jest zrobione
Sorry, I am a bit confused. Right now your menu is white in initial position and transparent on scroll, I though your would like to have the opposite effect.
Could you please explain?
Sorry, I am a bit confused. Right now your menu is white in initial position and transparent on scroll, I though your would like to have the opposite effect. Could you please explain? Gina
stryjek-www
Nie umiem zrobić tak aby nagłówek z menu był na slider ze zdjęciami tak jak na stronie http://www.sala-orchidea.pl/ . chodzi o to aby menu było na zdjęciu a nie na białym pasku. Mogę dać ci dane do panelu joomla
stryjek-www
chcę aby był takie samo jak na http://www.sala-orchidea.pl/
stryjek-www
http://salarozany.gpe.pl/administrator
login salarozany
pass Igorek1A
http://salarozany.gpe.pl/administrator login salarozany pass Igorek1A
1) Header has built-in feature to overlap next section:
2) As for the rest, I have added custom code to Home -> Settings -> Additional CSS.
1) Header has built-in feature to overlap next section: !Screenshot-2.png! 2) As for the rest, I have added custom code to Home -> Settings -> Additional CSS. Gina
stryjek-www
stryjek-www posted this 2 days ago
logo nie pomniejsza się, a chcę aby płynnie sie pomnijeszało
Sorry for the delay. As I can see you have already added transition property to the logo image.
Sorry for the delay. As I can see you have already added transition property to the logo image. Gina Themler Support
stryjek-www
stryjek-www posted this yesterday
tak dodałem sam ale logo jakoś dziwnie się pomniejsza. Przeskakuje w bok zanim się pomniejszy, widzisz to?
stryjek-www
mam kolejny problem. Na stronie głównej nagłówek jest ok. ale na pozostałych podstronach chcę aby był jakiegoś innego koloru , albo litery menu innego koloru bo nie widać ich na białym tle jak to zrobić?
stryjek-www
Jak w tym linku zrobić to aby nagłówek nachodził na zdęcie tak samo jak na stronie głównej?
http://salarozany.gpe.pl/o-nas
Jak w tym linku zrobić to aby nagłówek nachodził na zdęcie tak samo jak na stronie głównej? http://salarozany.gpe.pl/o-nas
Support Team posted this 1 hour ago
1) In order to differentiate the menu items color between Home page and other pages, you can add .bd-homepage class to the CSS for homepage, and .bd-body-7 class for other pages. For example:
.bd-body-7 .bd-menu-1.nav-pills .bd-menuitem-1:not(.bd-mega-item)>a, .bd-body-7 .bd-menu-1.nav-pills .bd-menuitem-1:not(.bd-mega-item)>a:link, .bd-body-7 .bd-menu-1.nav-pills .bd-menuitem-1:not(.bd-mega-item)>a:visited {
color:#555555!important;}
2) The logo doesn't shift to the left right now, you must have been already fixed it.
3) As for O NAS page, I can't provide custom CSS, since it will affect other pages as well.
Have you tried moving the section with the photo up by setting negative top margin?
Hello, 1) In order to differentiate the menu items color between Home page and other pages, you can add .bd-homepage class to the CSS for homepage, and .bd-body-7 class for other pages. For example: .bd-body-7 .bd-menu-1.nav-pills .bd-menuitem-1:not(.bd-mega-item)>a, .bd-body-7 .bd-menu-1.nav-pills .bd-menuitem-1:not(.bd-mega-item)>a:link, .bd-body-7 .bd-menu-1.nav-pills .bd-menuitem-1:not(.bd-mega-item)>a:visited { color:#555555!important;} 2) The logo doesn't shift to the left right now, you must have been already fixed it. 3) As for O NAS page, I can't provide custom CSS, since it will affect other pages as well. Have you tried moving the section with the photo up by setting negative top margin? Gina Themler Support
