PHP Warning: call_user_func() expects parameter 1 to be a valid callback
chinas
chinas posted this 22 October 2020
This is the error,
Warning: call_user_func() expects parameter 1 to be a valid callback, no array or string given in /sata2/home/users/qdoors/www/www.qdoors.com.ua/templates/qdoors_new/html/modules.php on line 57
It comes from a file of your template.
More specifically is that code:
call_user_func($styles[$style], $module, $params, $attribs);
Seems like your $styles var is empty.
From log:
[Thu Oct 22 15:51:22 2020] [warn] [client 88.81.226.126] mod_fcgid: stderr: PHP Warning:  call_user_func() expects parameter 1 to be a valid callback, no array or string given in /sata2/home/users/qdoors/www/www.qdoors.com.ua/templates/qdoors_new/html/modules.php on line 57, referer: https://www.qdoors.com.ua/index.php/produktsiya-vm
Hi This is the error, Warning: call_user_func() expects parameter 1 to be a valid callback, no array or string given in /sata2/home/users/qdoors/www/www.qdoors.com.ua/templates/qdoors_new/html/modules.php on line 57 It comes from a file of your template. More specifically is that code: call_user_func($styles[$style], $module, $params, $attribs); Seems like your $styles var is empty. From log: [Thu Oct 22 15:51:22 2020] [warn] [client 88.81.226.126] mod_fcgid: stderr: PHP Warning: call_user_func() expects parameter 1 to be a valid callback, no array or string given in /sata2/home/users/qdoors/www/www.qdoors.com.ua/templates/qdoors_new/html/modules.php on line 57, referer: https://www.qdoors.com.ua/index.php/produktsiya-vm
19 Comments
Support Team posted this 23 October 2020
Hello Yurii,
Please, try re-exporting the theme from Themler desktop and reinstall.
Themler support
Hello Yurii, Please, try re-exporting the theme from Themler desktop and reinstall. Gina Themler support
chinas
chinas posted this 24 October 2020
I followed your recommendation, but it didn't help.
I can give you administrative rights to the site
Attached template.
I followed your recommendation, but it didn't help. I can give you administrative rights to the site Attached template.
Support Team posted this 26 October 2020
Your theme is version 499, I have exported from version 517 and attached. Could you please test it?
Your theme is version 499, I have exported from version 517 and attached. Could you please test it? Gina Themler Support
chinas
chinas posted this 26 October 2020
I installed the template you suggested. It didn't help, I get the same error.
Support Team posted this 27 October 2020
This issue is forwarded to the developers. Meanwhile, you can try this:
1) Disable PHP warnings in Joomla. They are not affecting any functionality (if we are talking about warnings, not errors; in your case it is a warning),
2) Try changing that line of code to call_user_func(array($styles[$style], $module, $params, $attribs));
But please make sure you make the backup of the correct file so in case of an error, you could replace that file on the server.
Themler support
This issue is forwarded to the developers. Meanwhile, you can try this: 1) Disable PHP warnings in Joomla. They are not affecting any functionality (if we are talking about warnings, not errors; in your case it is a warning), 2) Try changing that line of code to `call_user_func(array($styles[$style], $module, $params, $attribs));` But please make sure you make the backup of the correct file so in case of an error, you could replace that file on the server. Gina Themler support
chinas
chinas posted this 27 October 2020
  1. I cannot ignore the error. Due to an error, part of the site's functionality does not work.
  2. I tried to replace the code snippet. It got worse, all modules were no longer displayed.
I can send a backup of the WEB-site, if necessary.
1. I cannot ignore the error. Due to an error, part of the site's functionality does not work. 2. I tried to replace the code snippet. It got worse, all modules were no longer displayed. I can send a backup of the WEB-site, if necessary.
Support Team posted this 28 October 2020
Could you please describe what functionality doesn't work?
Could you please describe what functionality doesn't work? Gina Themler Support
chinas
chinas posted this 29 October 2020
Module "Custom Filters" (https://extensions.joomla.org/extension/custom-filters-pro/) for VirtueMart does not work. When trying to filter a product by the selected parameters, the error mentioned above occurs and the display of the module disappears.
The module works with other templates without problems.
https://demo.breakdesigns.net/index.php/search/screens/
Module "Custom Filters" (https://extensions.joomla.org/extension/custom-filters-pro/) for VirtueMart does not work. When trying to filter a product by the selected parameters, the error mentioned above occurs and the display of the module disappears. The module works with other templates without problems. https://demo.breakdesigns.net/index.php/search/screens/
Support Team posted this 30 October 2020
Unfortunately, I can't fix incompatibility with 3rd party plugins.
I will forward this issue to the developers.
Themler support
Unfortunately, I can't fix incompatibility with 3rd party plugins. I will forward this issue to the developers. Gina Themler support
chinas
chinas posted this 04 November 2020
Let me know how the results will be from the developers.
chinas
chinas posted this 26 November 2020
Can you recommend a module for filtering products by custom fields that will be compatible with your template?
chinas
chinas posted this 03 December 2020
I have already tried several different product filters from different manufacturers. They all have the same compatibility issue with your templates. The same error is always returned.
I can provide all the necessary access to my WEB-site.
I have already tried several different product filters from different manufacturers. They all have the same compatibility issue with your templates. The same error is always returned. I can provide all the necessary access to my WEB-site.
dougpetersensei
dougpetersensei posted this 01 September 2023
The error message you're encountering, "PHP Warning: call_user_func() expects parameter 1 to be a valid callback," suggests that there's an issue with the callback function being passed in your code. Specifically, the $styles variable seems to be empty, resulting in the error. To resolve this, ensure that the $styles variable is properly initialized with valid callback functions. If you're looking to train for a career in hotel administration, addressing and debugging such technical challenges can be valuable in enhancing your problem-solving skills, which are essential in managing various aspects of a hotel's operations.
download Paint By Number - Coloring Book & Color by Number - v2.66.2 on Games.lol
The error message you're encountering, "PHP Warning: call_user_func() expects parameter 1 to be a valid callback," suggests that there's an issue with the callback function being passed in your code. Specifically, the $styles variable seems to be empty, resulting in the error. To resolve this, ensure that the $styles variable is properly initialized with valid callback functions. If you're looking [to train for a career in hotel administration][1], addressing and debugging such technical challenges can be valuable in enhancing your problem-solving skills, which are essential in managing various aspects of a hotel's operations. [download Paint By Number - Coloring Book & Color by Number - v2.66.2 on Games.lol][2] [1]: https://answersrepublic.com/education/how-to-become-a-hotel-manager/ [2]: https://games.lol/paint-by-number-coloring-book-color-by-number/
ckg94073
ckg94073 posted this 06 March 2024
Microsoft AZ-104 Exam Dumps are comprehensive study materials designed to help candidates prepare for the Microsoft Certified: Azure Administrator Associate certification exam (AZ-104). These exam dumps cover a wide range of topics and provide a thorough understanding of the skills and knowledge required to successfully pass the AZ-104 exam.
Many AZ-104 Exam Dumps include practice tests and sample questions that closely simulate the format and difficulty level of the actual exam. This allows candidates to familiarize themselves with the exam structure and improve their time management skills.
https://blogger.googleusercontent.com/img/b/R29vZ2xl/AVvXsEj2amJDcAOaFjgvVH5T3hGjwlTxbNgnX9pQx3KOLKwmpuBOC98F9JliEey2UCHZ1o0PfbiMPskZJwcPZWrrZLLUBfCr3clwFqvyqAgMFDiHlydXxTWc8oxrpgWlUuqLbaVMJDlZ0aaI0xqovbELSBJpcPwAjOiMhJashy4VYhnSgtGQh9yxWgjD4dHxBg/s900/Dumpsleader%20(1).jpg
It's essential for candidates to verify the credibility of the source from which they obtain their exam dumps to ensure the accuracy and reliability of the materials. Additionally, while exam dumps can be a valuable study resource, hands-on experience with Azure services is highly recommended to reinforce theoretical knowledge.
[Microsoft AZ-104 Exam Dumps][1] are comprehensive study materials designed to help candidates prepare for the Microsoft Certified: Azure Administrator Associate certification exam (AZ-104). These exam dumps cover a wide range of topics and provide a thorough understanding of the skills and knowledge required to successfully pass the AZ-104 exam. Many AZ-104 Exam Dumps include practice tests and sample questions that closely simulate the format and difficulty level of the actual exam. This allows candidates to familiarize themselves with the exam structure and improve their time management skills. ![https://blogger.googleusercontent.com/img/b/R29vZ2xl/AVvXsEj2amJDcAOaFjgvVH5T3hGjwlTxbNgnX9pQx3KOLKwmpuBOC98F9JliEey2UCHZ1o0PfbiMPskZJwcPZWrrZLLUBfCr3clwFqvyqAgMFDiHlydXxTWc8oxrpgWlUuqLbaVMJDlZ0aaI0xqovbELSBJpcPwAjOiMhJashy4VYhnSgtGQh9yxWgjD4dHxBg/s900/Dumpsleader%20(1).jpg][2] It's essential for candidates to verify the credibility of the source from which they obtain their exam dumps to ensure the accuracy and reliability of the materials. Additionally, while exam dumps can be a valuable study resource, hands-on experience with Azure services is highly recommended to reinforce theoretical knowledge. [1]: https://www.dumpsleader.com/AZ-104-exam-dumps.html [2]: https://blogger.googleusercontent.com/img/b/R29vZ2xl/AVvXsEj2amJDcAOaFjgvVH5T3hGjwlTxbNgnX9pQx3KOLKwmpuBOC98F9JliEey2UCHZ1o0PfbiMPskZJwcPZWrrZLLUBfCr3clwFqvyqAgMFDiHlydXxTWc8oxrpgWlUuqLbaVMJDlZ0aaI0xqovbELSBJpcPwAjOiMhJashy4VYhnSgtGQh9yxWgjD4dHxBg/s900/Dumpsleader%20%281%29.jpg
janejlocane
janejlocane posted this 22 October 2024
It is very important to observe such parameters when writing a program. I take programming courses. Studying there was more successful than at the university. I began to fall behind in some subjects. Then I started using the writing service essay and thanks to this I finished the academic year well. I was able to complete coursework, essays, and several research papers. My academic performance has become much better.
It is very important to observe such parameters when writing a program. I take programming courses. Studying there was more successful than at the university. I began to fall behind in some subjects. Then I started using the [writing service essay][1] and thanks to this I finished the academic year well. I was able to complete coursework, essays, and several research papers. My academic performance has become much better. [1]: https://essaybox.org/
martinemma989
martinemma989 posted this 22 April 2025
This is useful, and I appreciate you pointing out the mistake. This problem seriously impairs a website's functionality. Similarly, London CIPD Assignment Help guarantees that academic assignments are properly organized and devoid of errors, assisting students in avoiding typical blunders and succeeding. smothly
This is useful, and I appreciate you pointing out the mistake. This problem seriously impairs a website's functionality. Similarly, [London CIPD Assignment Help][1] guarantees that academic assignments are properly organized and devoid of errors, assisting students in avoiding typical blunders and succeeding. smothly [1]: https://cipdassignmenthelp.uk.com/
Amanda Parsons
Amanda Parsons posted this 20 May 2025
Thanks for sharing the PHP error details. They are helpful for debugging! For students managing coding projects and academics, Dissertation Editing Services can polish your research to perfection. Great catch on the $styles variable issue!
Thanks for sharing the PHP error details. They are helpful for debugging! For students managing coding projects and academics, [Dissertation Editing Services][1] can polish your research to perfection. Great catch on the $styles variable issue! [1]: https://ukdissertationhelp.uk/dissertation-editing
johns
johns posted this 11 September 2025
My experience with DumpsCollection was great and memorable. The mentors helped me to enhance my academic and interpersonal skills. The PDF+Testing Engine of ACAMS CKYCA exam was impeccable. Thank you so much for serving us
My experience with DumpsCollection was great and memorable. The mentors helped me to enhance my academic and interpersonal skills. The PDF+Testing Engine of [ACAMS CKYCA exam][1] was impeccable. Thank you so much for serving us [1]: https://www.dumpscollection.com/CKYCA-exam.html
edwardmullin4
edwardmullin4 posted this 13 February 2026
Civil Engineering Lab Equipment is widely used across the globe for testing and research purposes. The long term partnership and zero complaint record prove that our products are of modern technology, have efficient design, amazing durability, and are made of superior quality material. Atico serves various industries, including construction industries, colleges and universities, research laboratories, and quality control departments. Civil Engineering Lab Equipments made by Atico help institutions uphold high standards of quality and safety. Atico has built a reputation as a reliable name in Civil Engineering Lab Equipment Manufacturers by prioritising customer satisfaction, giving trustworthy performance, and consistent progress.
Civil Engineering Lab Equipment is widely used across the globe for testing and research purposes. The long term partnership and zero complaint record prove that our products are of modern technology, have efficient design, amazing durability, and are made of superior quality material. Atico serves various industries, including construction industries, colleges and universities, research laboratories, and quality control departments. Civil Engineering Lab Equipments made by Atico help institutions uphold high standards of quality and safety. Atico has built a reputation as a reliable name in **[Civil Engineering Lab Equipment Manufacturers][1]** by prioritising customer satisfaction, giving trustworthy performance, and consistent progress. [1]: https://www.aticoexports.com/category/civil-engineering-lab-equipment
