wordpress slider eror
9140053016
9140053016 posted this 06 November 2020
i have a themler slide and i add a cms code in to slide1
Problem1
when i make duplicate slide it's not working.
Problem2
when i want to make new one its not working.
Problem3
i writed a slider plugin and its not working in themler.
my cms code 1
<?php wp_query arguments $args ( 'post_type'?> array( 'turlar' ),
'post_status' => array( 'publish' ),
'nopaging' => false,
'posts_per_page' => '1',
'offset' => '0',
'order' => 'DESC',
'orderby' => 'date',
'cache_results' => true,
'update_post_meta_cache' => true,
'update_post_term_cache' => true,
// The Query
$query_themler_image = new WP_Query( $args );
// The Loop
if ( $query_themler_image->have_posts() ) {
while ( $query_themler_image->have_posts() ) {
$query_themler_image->the_post();
// do something
echo '<a href title>';
if (has_post_thumbnail()):
the_post_thumbnail();
endif;
echo '</a>';
} else {
// no posts found
echo 'No description found';
// Restore original Post Data
wp_reset_postdata();
my cms code2
'offset' => '0',
'order' => 'DESC',
// The Query
$query_themler_desc = new WP_Query( $args );
// The Loop
if ( $query_themler_desc->have_posts() ) {
while ( $query_themler_desc->have_posts() ) {
$query_themler_desc->the_post();
<h1 class="entry-title">
    <a href="<?php echo esc_url( get_permalink($turlar_id) ); ?>">
        <?php echo get_page($turlar_id)->post_title; ?>
    </a>
</h1>
<div class>Gidiş Tarihi :<?php echo esc_html( get_post_meta( get_the_id(), 'tarih', true ) );?>
 <div class="entry-content">Dönüş Tarihi :<?php echo esc_html( get_post_meta( get_the_ID(), 'tarih_b', true ) ); ?>
 <p><?php echo esc_html( get_post_meta( get_the_ID(), 'tur_suresi', true ) ); ?></p><p><?php echo esc_html( get_post_meta( get_the_ID(), 'fiyat', true ) ); ?></p>
      </div> <button type="button">Turu İncele</button></a>
<?php } } else { no posts found echo 'no description found'; } restore original post data wp_reset_postdata();?>
and my slider plugin front end codes
<div class>
  <?php
  $arg = array(
     'post_type'         => array( 'slidere' ),
     'posts_per_page'    => 10,
     'order'             => 'asc'
  $slidere = new WP_Query($arg);
  $j = 0;
  $post_count = wp_count_posts('slidere')->publish;
  <!-- Carousel -->
  <div id="carousel-example-generic" class="carousel slide" data-ride="carousel">
     <!-- Indicators -->
     <ol class="carousel-indicators">
            <?php for($i=0;$i<$post_count; $i++): ?>
        <li data-target="#carousel-example-generic" data-slide-to="<?php echo $i; ?>" class="active"></li>
            <?php endfor; ?>
     </ol>
     <!-- Wrapper for slides -->
     <div class="carousel-inner" style="width: 100%;max-height: 460px">
            <?php while($slidere->have_posts()) : $slidere->the_post(); ?>
        <div class="item<?php echo $j==0 ? ' active': '';?>">
          <span><?php if(has_post_thumbnail()): the_post_thumbnail('slidere'); endif; ?> </span>
           <!-- Static Header -->
           <div class="header-text23 hidden-xs" style="position:absolute;top: 20%;left: 1.8%;right: auto;width: 96.66666666666666%;color: #fff;">
              <div class="col-md-12 text-center">
                 <h2>
                    <span> <strong><?php the_title() ?></strong></span>
                 </h2>
                 <br>
                 <h3>
                            <a href="<?php echo get_post_meta(get_the_ID(),'_slidere_link_value_key', true); ?>"><span><?php the_excerpt(); ?></span></a>
                 </h3>
              </div>
           </div><!-- /header-text -->
        </div>
            <?php $j++; endWhile; wp_reset_query(); ?>
     </div>
     <!-- Controls -->
     <a class="left carousel-control" style="opacity: 1;filter:alpha(opacity=100);background-image: none;background-repeat: no-repeat;text-shadow: none;padding: 15px;" href="#carousel-example-generic" data-slide="prev">
        <span class="glyphicon glyphicon-chevron-left" style="position: absolute;top: 45%;z-index: 5;display: inline-block;left: 0;"></span>
     </a>
     <a class="right carousel-control" style="opacity: 1;filter:alpha(opacity=100);background-image: none;background-repeat: no-repeat;text-shadow: none;padding: 15px;" href="#carousel-example-generic" data-slide="next">
        <span class="glyphicon glyphicon-chevron-right" style="position: absolute;top: 45%;z-index: 5;display: inline-block;right: 0;"></span>
     </a>
  </div><!-- /carousel -->
please help
i bored themler
i have a themler slide and i add a cms code in to slide1 Problem1 when i make duplicate slide it's not working. Problem2 when i want to make new one its not working. Problem3 i writed a slider plugin and its not working in themler. my cms code 1 &lt;?php wp_query arguments $args ( &#39;post_type&#39;?&gt; array( 'turlar' ), 'post_status' => array( 'publish' ), 'nopaging' => false, 'posts_per_page' => '1', 'offset' => '0', 'order' => 'DESC', 'orderby' => 'date', 'cache_results' => true, 'update_post_meta_cache' => true, 'update_post_term_cache' => true, ); // The Query $query_themler_image = new WP_Query( $args ); // The Loop if ( $query_themler_image->have_posts() ) { while ( $query_themler_image->have_posts() ) { $query_themler_image->the_post(); // do something echo '&lt;a href title&gt;&#39;; if (has_post_thumbnail()): the_post_thumbnail(); endif; echo &#39;&lt;/a&gt;'; } } else { // no posts found echo 'No description found'; } // Restore original Post Data wp_reset_postdata(); ?> my cms code2 &lt;?php wp_query arguments $args ( &#39;post_type&#39;?&gt; array( 'turlar' ), 'post_status' => array( 'publish' ), 'nopaging' => false, 'posts_per_page' => '1', 'offset' => '0', 'order' => 'DESC', 'orderby' => 'date', 'cache_results' => true, 'update_post_meta_cache' => true, 'update_post_term_cache' => true, ); // The Query $query_themler_desc = new WP_Query( $args ); // The Loop if ( $query_themler_desc->have_posts() ) { while ( $query_themler_desc->have_posts() ) { $query_themler_desc->the_post(); ?> <h1 class="entry-title"> <a href="<?php echo esc_url( get_permalink($turlar_id) ); ?>"> <?php echo get_page($turlar_id)->post_title; ?> </a> </h1> &lt;div class&gt;Gidiş Tarihi :&lt;?php echo esc_html( get_post_meta( get_the_id(), &#39;tarih&#39;, true ) );?&gt; <div class="entry-content">Dönüş Tarihi :<?php echo esc_html( get_post_meta( get_the_ID(), 'tarih_b', true ) ); ?> <p><?php echo esc_html( get_post_meta( get_the_ID(), 'tur_suresi', true ) ); ?></p><p><?php echo esc_html( get_post_meta( get_the_ID(), 'fiyat', true ) ); ?></p> <a href="<?php echo esc_url( get_permalink($turlar_id) ); ?>"> </div> <button type="button">Turu İncele</button></a> &lt;?php } } else { no posts found echo &#39;no description found&#39;; } restore original post data wp_reset_postdata();?&gt; and my slider plugin front end codes &lt;div class&gt; <?php $arg = array( 'post_type' => array( 'slidere' ), 'posts_per_page' => 10, 'order' => 'asc' ); $slidere = new WP_Query($arg); $j = 0; $post_count = wp_count_posts('slidere')->publish; ?> <!-- Carousel --> <div id="carousel-example-generic" class="carousel slide" data-ride="carousel"> <!-- Indicators --> <ol class="carousel-indicators"> <?php for($i=0;$i<$post_count; $i++): ?> <li data-target="#carousel-example-generic" data-slide-to="<?php echo $i; ?>" class="active"></li> <?php endfor; ?> </ol> <!-- Wrapper for slides --> <div class="carousel-inner" style="width: 100%;max-height: 460px"> <?php while($slidere->have_posts()) : $slidere->the_post(); ?> <div class="item<?php echo $j==0 ? ' active': '';?>"> <span><?php if(has_post_thumbnail()): the_post_thumbnail('slidere'); endif; ?> </span> <!-- Static Header --> <div class="header-text23 hidden-xs" style="position:absolute;top: 20%;left: 1.8%;right: auto;width: 96.66666666666666%;color: #fff;"> <div class="col-md-12 text-center"> <h2> <span> <strong><?php the_title() ?></strong></span> </h2> <br> <h3> <a href="<?php echo get_post_meta(get_the_ID(),'_slidere_link_value_key', true); ?>"><span><?php the_excerpt(); ?></span></a> </h3> </div> </div><!-- /header-text --> </div> <?php $j++; endWhile; wp_reset_query(); ?> </div> <!-- Controls --> <a class="left carousel-control" style="opacity: 1;filter:alpha(opacity=100);background-image: none;background-repeat: no-repeat;text-shadow: none;padding: 15px;" href="#carousel-example-generic" data-slide="prev"> <span class="glyphicon glyphicon-chevron-left" style="position: absolute;top: 45%;z-index: 5;display: inline-block;left: 0;"></span> </a> <a class="right carousel-control" style="opacity: 1;filter:alpha(opacity=100);background-image: none;background-repeat: no-repeat;text-shadow: none;padding: 15px;" href="#carousel-example-generic" data-slide="next"> <span class="glyphicon glyphicon-chevron-right" style="position: absolute;top: 45%;z-index: 5;display: inline-block;right: 0;"></span> </a> </div><!-- /carousel --> please help i bored themler
Support Team posted this 06 November 2020
We don't support 3rd party code integrated to Themler.
Could you please describe why standard slider than Themler provides doesn't work for you?
Hello, We don't support 3rd party code integrated to Themler. Could you please describe why standard slider than Themler provides doesn't work for you? Gina Themler Support
9140053016
9140053016 posted this 16 November 2020
İ dont Know why but its not working
9140053016
standars slider is not working too
Support Team posted this 17 November 2020
What is not working exactly? The animation doesn't work?
Could you please provide temporary access to your wp-admin and specify where the sider is?
What is not working exactly? The animation doesn't work? Could you please provide temporary access to your wp-admin and specify where the sider is? Gina Themler Support
