Lack of Templates in Wordpress
bruchlag
bruchlag posted this 14 August 2015
I have created a Wordpress theme with a number of templates in addition to the default ones. However, when I install the theme and try to edit a page, I can only see the default and home page templates in the editor.
What am I doing wrong?
Peter
I have created a Wordpress theme with a number of templates in addition to the default ones. However, when I install the theme and try to edit a page, I can only see the default and home page templates in the editor. What am I doing wrong? Thanks Peter
11 Comments
Support Team posted this 14 August 2015
Please refer to the following link:
http://answers.themler.com/articles/9466/how-to-create-and-use-custom-templates
You need to create the new template of the page or post type to see it in the list.
Hi, Please refer to the following link: http://answers.themler.com/articles/9466/how-to-create-and-use-custom-templates You need to create the new template of the page or post type to see it in the list. Sincerely, Hella BillionDigital Team
mycapstone
mycapstone posted this 07 November 2015
I don't think you understood the problem. The custom templates are not listed in the page editor. You can't select the custom template because it's not in the drop down list.
mycapstone
I this this is the problem. Themler doesn't do this.
Check that each of your custom templates have the following block at the very top of the file:
<?php template name: = name_of_template_for_dropdown ?>
I this this is the problem. Themler doesn't do this. Check that each of your custom templates have the following block at the very top of the file: &lt;?php template name: = name_of_template_for_dropdown ?&gt;
Support Team posted this 09 November 2015
Let us know how to reproduce the issue. You create the theme with number of custom templates, export it, install in WP site and then when opening the Themler editor, the custom templates are not there?
Hi, Let us know how to reproduce the issue. You create the theme with number of custom templates, export it, install in WP site and then when opening the Themler editor, the custom templates are not there? Sincerely, Hella
twomfi
twomfi posted this 22 November 2015
I am also having the same pronle. The issue issue is that, after installating the created theme by themler, and creating Home and blog pages, and linking as statc pages within the Reading Section; when creating creating a Page, there is no way of my specifying that that page being created is a blog. The only uption is the Default Template and the Home Template
twomfi
Okay I got it now.
Simple put >>>>> Create a custom template>>>> it could be a modified copy of the main page template>>> save under another name and then you will see it when creating a new page.
hope that helps
Okay I got it now. Simple put >>>>> Create a custom template>>>> it could be a modified copy of the main page template>>> save under another name and then you will see it when creating a new page. hope that helps
Support Team posted this 23 November 2015
You are right. The Blog template is applied to the blog pages only, you can not select it for any other page. This article may be helpful:
Hi, You are right. The Blog template is applied to the blog pages only, you can not select it for any other page. This article may be helpful: http://answers.themler.com/articles/9466/how-to-create-and-use-custom-templates Sincerely, Hella
DFG
DFG posted this 06 December 2015
Hi!
I have the same problem as described in initial post.
I can not get Templates listed under Custom, but Template listed under Main, is available in WP CMS.
http://i.imgur.com/2efwbfl.png
http://i.imgur.com/oqlV8jm.png
Why is that?
I have followed this http://answers.themler.com/articles/9466/how-to-create-and-use-custom-templates, and other answers, and based on them my expectation is to have every template available in WP CMS.
Regards, dfg
Hi! I have the same problem as described in initial post. I can not get Templates listed under Custom, but Template listed under Main, is available in WP CMS. http://i.imgur.com/2efwbfl.png http://i.imgur.com/oqlV8jm.png Why is that? I have followed this http://answers.themler.com/articles/9466/how-to-create-and-use-custom-templates, and other answers, and based on them my expectation is to have every template available in WP CMS. Regards, dfg
Support Team posted this 09 December 2015
@ DiFotoGraf ,
please submit new private topic and provide access to your WP admin back end.
@ DiFotoGraf , please submit new private topic and provide access to your WP admin back end. regards, Aileen
Ermes Multimedia
Ermes Multimedia posted this 08 February 2016
Good morning i have the same issue.
I created a news template for the news category of my site, but themler does not show my custom template in the template list, so i don't know how to edit it
Good morning i have the same issue. I created a news template for the news category of my site, but themler does not show my custom template in the template list, so i don't know how to edit it
Support Team posted this 09 February 2016
You do not see the template you have added within the template list in Themler? In this case please create a private topic and provide access to your site back end so we could investigate the issue.
Hi, You do not see the template you have added within the template list in Themler? In this case please create a private topic and provide access to your site back end so we could investigate the issue. Sincerely, Hella
