is there the possibility to create a theme with themler Desktop on the first pc and view that theme created on themler Desktop on the second pc?
thanks.
thanks.
Yes, this is possible. Use Export theme option for this and then import the theme in new Themler desktop instance.
good morning, but nothing can be saved online?
if one day my pc breaks down, can't i recover anything?
then put your theme on a test environment.
so you can work on different computers on the same team, without being afraid to loose it
We recommend, to make theme backups from time to time (for example, just export a zip) to store them somewhere on a hard drive, portable drive or some external cloud service. Also, when your theme is ready and you install it on some hosted website, it is stored on the hosting as well.
