Sorry, an error has occurred. Please clear your browser cache.
cyrylsochacki
cyrylsochacki posted this 15 December 2020
Hello.
I have a problem with entering some pages and editing their templates in last ver Joomla:
"Sorry, an error has occurred. Please clear your browser cache"
I do not use a desktop application. I work through the joomla facilities and edit templates.
I have assumed that the problem occurs with <500 page versions which have versions over 500 i can edit.
i'll also add that even though it gives me information about clearing the browser is not a problem because i tried to edit sabers on different browsers and systems. templates above 500 can be easily edited. all older templates below 500 receive this message. even a clean template from you has this problem because it is in version 499.
of course i've cleaned the data of the browsers and so on.
page versions which have versions over 500 i can edit. i'll also add that even though it gives me information about clearing the browser is not a problem because i tried to edit sabers on different browsers and systems. templates above 500 can be easily edited. all older templates below 500 receive this message. even a clean template from you has this problem because it is in version 499. of course i've cleaned the data of the browsers and so on.
page versions which have versions over 500 i can edit. i'll also add that even though it gives me information about clearing the browser is not a problem because i tried to edit sabers on different browsers and systems. templates above 500 can be easily edited. all older templates below 500 receive this message. even a clean template from you has this problem because it is in version 499. of course i've cleaned the data of the browsers and so on. page versions which have versions over 500 i can edit. i'll also add that even though it gives me information about clearing the browser is not a problem because i tried to edit sabers on different browsers and systems. templates above 500 can be easily edited. all older templates below 500 receive this message. even a clean template from you has this problem because it is in version 499. of course i've cleaned the data of the browsers and so on.
page versions which have versions over 500 i can edit. i'll also add that even though it gives me information about clearing the browser is not a problem because i tried to edit sabers on different browsers and systems. templates above 500 can be easily edited. all older templates below 500 receive this message. even a clean template from you has this problem because it is in version 499. of course i've cleaned the data of the browsers and so on. page versions which have versions over 500 i can edit. i'll also add that even though it gives me information about clearing the browser is not a problem because i tried to edit sabers on different browsers and systems. templates above 500 can be easily edited. all older templates below 500 receive this message. even a clean template from you has this problem because it is in version 499. of course i've cleaned the data of the browsers and so on. page versions which have versions over 500 i can edit. i'll also add that even though it gives me information about clearing the browser is not a problem because i tried to edit sabers on different browsers and systems. templates above 500 can be easily edited. all older templates below 500 receive this message. even a clean template from you has this problem because it is in version 499. of course i've cleaned the data of the browsers and so on. page versions which have versions over 500 i can edit. i'll also add that even though it gives me information about clearing the browser is not a problem because i tried to edit sabers on different browsers and systems. templates above 500 can be easily edited. all older templates below 500 receive this message. even a clean template from you has this problem because it is in version 499. of course i've cleaned the data of the browsers and so on.
Hello. I have a problem with entering some pages and editing their templates in last ver Joomla: "Sorry, an error has occurred. Please clear your browser cache" I do not use a desktop application. I work through the joomla facilities and edit templates. I have assumed that the problem occurs with &lt;500 page versions which have versions over 500 i can edit. i&#39;ll also add that even though it gives me information about clearing the browser is not a problem because i tried to edit sabers on different browsers and systems. templates above 500 can be easily edited. all older templates below 500 receive this message. even a clean template from you has this problem because it is in version 499. of course i&#39;ve cleaned the data of the browsers and so on. page versions which have versions over 500 i can edit. i&#39;ll also add that even though it gives me information about clearing the browser is not a problem because i tried to edit sabers on different browsers and systems. templates above 500 can be easily edited. all older templates below 500 receive this message. even a clean template from you has this problem because it is in version 499. of course i&#39;ve cleaned the data of the browsers and so on. page versions which have versions over 500 i can edit. i&#39;ll also add that even though it gives me information about clearing the browser is not a problem because i tried to edit sabers on different browsers and systems. templates above 500 can be easily edited. all older templates below 500 receive this message. even a clean template from you has this problem because it is in version 499. of course i&#39;ve cleaned the data of the browsers and so on. page versions which have versions over 500 i can edit. i&#39;ll also add that even though it gives me information about clearing the browser is not a problem because i tried to edit sabers on different browsers and systems. templates above 500 can be easily edited. all older templates below 500 receive this message. even a clean template from you has this problem because it is in version 499. of course i&#39;ve cleaned the data of the browsers and so on. page versions which have versions over 500 i can edit. i&#39;ll also add that even though it gives me information about clearing the browser is not a problem because i tried to edit sabers on different browsers and systems. templates above 500 can be easily edited. all older templates below 500 receive this message. even a clean template from you has this problem because it is in version 499. of course i&#39;ve cleaned the data of the browsers and so on. page versions which have versions over 500 i can edit. i&#39;ll also add that even though it gives me information about clearing the browser is not a problem because i tried to edit sabers on different browsers and systems. templates above 500 can be easily edited. all older templates below 500 receive this message. even a clean template from you has this problem because it is in version 499. of course i&#39;ve cleaned the data of the browsers and so on. page versions which have versions over 500 i can edit. i&#39;ll also add that even though it gives me information about clearing the browser is not a problem because i tried to edit sabers on different browsers and systems. templates above 500 can be easily edited. all older templates below 500 receive this message. even a clean template from you has this problem because it is in version 499. of course i&#39;ve cleaned the data of the browsers and so on. page versions which have versions over 500 i can edit. i&#39;ll also add that even though it gives me information about clearing the browser is not a problem because i tried to edit sabers on different browsers and systems. templates above 500 can be easily edited. all older templates below 500 receive this message. even a clean template from you has this problem because it is in version 499. of course i&#39;ve cleaned the data of the browsers and so on.
18 Comments
Support Team posted this 16 December 2020
Please try this way with any of the older themes:
1. Copy the theme from the website via FTP
2. Zip-compress it
3. Import in Themler desktop
4. Update it to the latest Themler version. You may need to update Beta update notifications in your profile for this.
5. Export the theme under a different name
6. Install the theme in your CMS.
Hello, Please try this way with any of the older themes: 1. Copy the theme from the website via FTP 2. Zip-compress it 3. Import in Themler desktop 4. Update it to the latest Themler version. You may need to update Beta update notifications in your profile for this. 5. Export the theme under a different name 6. Install the theme in your CMS. Sincerely, Nettie
pvcmloza
pvcmloza posted this 15 June 2024
Well-executed renovations not only enhance the aesthetic appeal and functionality of a home but also contribute to long-term property maintenance and value preservation. Renovation contractors prioritize durable materials, quality craftsmanship, and proper installation techniques that withstand wear and tear over time check service detail. This proactive approach minimizes the need for future repairs and upgrades, preserving the home's structural integrity and market value. By investing in renovations, homeowners safeguard their investment and ensure continued enjoyment and appreciation of their property for years to come.
Well-executed renovations not only enhance the aesthetic appeal and functionality of a home but also contribute to long-term property maintenance and value preservation. Renovation contractors prioritize durable materials, quality craftsmanship, and proper installation techniques that withstand wear and tear over time [check service detail][1]. This proactive approach minimizes the need for future repairs and upgrades, preserving the home's structural integrity and market value. By investing in renovations, homeowners safeguard their investment and ensure continued enjoyment and appreciation of their property for years to come. [1]: https://walkergeneralcontractors.ca/home-bathroom-kitchen-renovation-burnaby/
sovaoks
sovaoks posted this 18 June 2024
Cannabis is widely recognized for its analgesic properties, making it effective in treating chronic pain conditions such as arthritis, fibromyalgia, and neuropathic pain https://getrolld.ca/.
pvcmloza
pvcmloza posted this 21 September 2024
don’t underestimate the power of renovations to increase home comfort and relaxation. A thoughtfully redesigned kitchen makes meal prep more enjoyable and can create a warm, inviting space for social gatherings. In the bathroom, comfort is elevated with the addition of luxury features like rainfall showers nyc kitchen and bath, deep soaking tubs, or heated towel racks. These upgrades provide a spa-like atmosphere where you can unwind after a long day in the city. The ability to turn daily routines into moments of relaxation is one of the most rewarding aspects of a renovation, as it enhances not just the look of your home but also the way you experience it.
don’t underestimate the power of renovations to increase home comfort and relaxation. A thoughtfully redesigned kitchen makes meal prep more enjoyable and can create a warm, inviting space for social gatherings. In the bathroom, comfort is elevated with the addition of luxury features like rainfall showers [nyc kitchen and bath][1], deep soaking tubs, or heated towel racks. These upgrades provide a spa-like atmosphere where you can unwind after a long day in the city. The ability to turn daily routines into moments of relaxation is one of the most rewarding aspects of a renovation, as it enhances not just the look of your home but also the way you experience it. [1]: https://www.myhomeus.com/blog/nyc-kitchen-design-upper-west-side/
eja.ge.r.m
eja.ge.r.m posted this 12 June 2025
med spas provide a relaxing, spa-like environment combined with the confidence of medical oversight. This hybrid setting helps clients feel at ease while receiving treatments that might otherwise be intimidating in a clinical atmosphere. It bridges the gap between beauty and medicine https://enrichedmedspa.com/ , offering a comprehensive, high-quality experience that promotes confidence, youthfulness, and vitality.
holdenmann54
holdenmann54 posted this 29 September 2025
Just like carpets and floors need proper care, your sofas, chairs, and other furniture also deserve attention to stay fresh and comfortable. Professional upholstery cleaning Brisbane helps remove hidden dust, stains, and allergens that everyday vacuuming can’t reach. At SafeClean, we use safe and gentle methods to bring new life to your furniture, leaving your home cleaner, healthier, and more inviting.
Just like carpets and floors need proper care, your sofas, chairs, and other furniture also deserve attention to stay fresh and comfortable. Professional [upholstery cleaning Brisbane][1] helps remove hidden dust, stains, and allergens that everyday vacuuming can’t reach. At SafeClean, we use safe and gentle methods to bring new life to your furniture, leaving your home cleaner, healthier, and more inviting. [1]: https://safeclean.com.au/upholstery-cleaning-brisbane/
henryashford663
henryashford663 posted this 21 October 2025
1: https://safeclean.com.au/upholstery-cleaning-brisbane/
Absolutely! Just like upholstery needs proper care, your furniture in Dubai can benefit from professional attention. A reliable dubai cleaning company can remove dust, stains, and allergens from sofas and chairs, keeping your home fresh, healthy, and inviting.
> Just like carpets and floors need proper care, your sofas, chairs, and other furniture also deserve attention to stay fresh and comfortable. Professional [upholstery cleaning Brisbane][1] helps remove hidden dust, stains, and allergens that everyday vacuuming can’t reach. At SafeClean, we use safe and gentle methods to bring new life to your furniture, leaving your home cleaner, healthier, and more inviting. > > > [1]: https://safeclean.com.au/upholstery-cleaning-brisbane/ Absolutely! Just like upholstery needs proper care, your furniture in Dubai can benefit from professional attention. A reliable [dubai cleaning company][1] can remove dust, stains, and allergens from sofas and chairs, keeping your home fresh, healthy, and inviting. [1]: http://newomniyatcleaning.ae
amnap6771
amnap6771 posted this 15 November 2025
Lahore stands out as a leading hub for premium home and office furniture in Pakistan, offering a unique mix of traditional artistry and modern designs. Whether you're decorating a new space or upgrading your workplace, the city’s top furniture stores deliver quality, durability, and stylish solutions that cater to every taste. Perfect for anyone seeking elegant, long-lasting furniture. https://officerepublic.pk/
jaffariqbal7663
jaffariqbal7663 posted this 17 November 2025
Lahore, known for its deep cultural roots, artistic heritage, and growing urban lifestyle, has one of Pakistan’s most dynamic furniture markets. The city offers a remarkable range of furniture styles, each reflecting a unique blend of traditional craftsmanship and modern design. Whether you are furnishing a new home, redecorating a workspace, or searching for exclusive handcrafted pieces, Lahore provides countless options to suit different tastes, budgets, and interior themes. https://profine.pk/
jotane5612
jotane5612 posted this 16 December 2025
Quava Runtz bursts with a dynamic spirit, blending vibrant color and rhythmic urban energy. Its aromatic profile inspires creativity, making it a favorite among artists and city dwellers seeking a lively spark. The Quava Runtz Strain delivers a playful, uplifting effect that enhances imagination and fuels expressive moments. Streets, studios, and social gatherings come alive with its presence, reflecting a culture that thrives on movement and spontaneity. This strain embodies the synergy of sensory stimulation and urban lifestyle, leaving a lasting impression on those who embrace its creative pulse.
Quava Runtz bursts with a dynamic spirit, blending vibrant color and rhythmic urban energy. Its aromatic profile inspires creativity, making it a favorite among artists and city dwellers seeking a lively spark. The [Quava Runtz Strain][1] delivers a playful, uplifting effect that enhances imagination and fuels expressive moments. Streets, studios, and social gatherings come alive with its presence, reflecting a culture that thrives on movement and spontaneity. This strain embodies the synergy of sensory stimulation and urban lifestyle, leaving a lasting impression on those who embrace its creative pulse. [1]: https://runtzstrainstore.com/
luxiwz
luxiwz posted this 17 December 2025
The Fragrant Flower Blooms with Dignity manga is by Saka Mikami about Kaoruko Waguri, a refined girl from an elite high school, and Rintaro Tsumugi, an earnest boy from a working-class school nearby.
[The Fragrant Flower Blooms with Dignity manga][1] is by Saka Mikami about Kaoruko Waguri, a refined girl from an elite high school, and Rintaro Tsumugi, an earnest boy from a working-class school nearby. [1]: https://thefragrantflowerbloomswithdignity.xyz/
samuellewisd879
samuellewisd879 posted this 17 December 2025
It sounds like the issue may be related to how older versions are handled rather than a simple cache problem. Along with the suggested steps, it can also help to update or re-export legacy templates so they align with current system limits. When technical troubleshooting gets frustrating, taking a short break with something relaxing using PvZ Fusion Niejo can clear your head before coming back to test solutions more calmly.
It sounds like the issue may be related to how older versions are handled rather than a simple cache problem. Along with the suggested steps, it can also help to update or re-export legacy templates so they align with current system limits. When technical troubleshooting gets frustrating, taking a short break with something relaxing using [PvZ Fusion Niejo][1] can clear your head before coming back to test solutions more calmly. [1]: https://thepvzzfusion.com/
muntahaseo71
muntahaseo71 posted this 16 February 2026
Chairs in Pakistan are available in a wide variety of designs, materials, and price ranges to suit homes and offices. From ergonomic office chairs to stylish dining and lounge chairs, customers can find affordable and premium options. Modern brands focus on comfort, durability, and customization to meet different interior needs and preferences.
[Chairs in Pakistan][1] are available in a wide variety of designs, materials, and price ranges to suit homes and offices. From ergonomic office chairs to stylish dining and lounge chairs, customers can find affordable and premium options. Modern brands focus on comfort, durability, and customization to meet different interior needs and preferences. [1]: https://profine.pk/product-category/office-chairs/
calculadoradehoras978
calculadoradehoras978 posted this 18 February 2026
“OfficeRepublic offers top-quality office chair combining comfort and style.
“OfficeRepublic offers top-quality [office chair][1] combining comfort and style. [1]: https://officerepublic.pk/product-category/chairs/
sofaupholsterer
sofaupholsterer posted this 17 April 2026
Is your outdoor sofa fabric cracked, stained, or torn? Sofa Upholsterer in Al Quoz, Dubai, provides professional outdoor upholstery repair and restoration services that extend the life of your garden and patio furniture. We understand that outdoor pieces face harsh conditions – intense heat, dust storms, and occasional rain.
Is your outdoor sofa fabric cracked, stained, or torn? Sofa Upholsterer in Al Quoz, Dubai, provides **[professional outdoor upholstery][1]** repair and restoration services that extend the life of your garden and patio furniture. We understand that outdoor pieces face harsh conditions – intense heat, dust storms, and occasional rain. [1]: https://sofaupholsterer.ae/upholstery/outdoor/
oliverapks
oliverapks posted this 06 May 2026
This error is quite common with Themler and not always just about cache. In many cases, it’s related to plugin conflicts, updates, or even CMS issues like VirtueMart or Joomla components
Try clearing cache, disabling plugins temporarily, and checking recent updates — that usually helps.
Interestingly, it reminds me of the idea behind flor de loto significado — even when things get messy or unclear (like this error), there’s usually a clean solution underneath if you take the right steps.
This error is quite common with Themler and not always just about cache. In many cases, it’s related to plugin conflicts, updates, or even CMS issues like VirtueMart or Joomla components Try clearing cache, disabling plugins temporarily, and checking recent updates — that usually helps. Interestingly, it reminds me of the idea behind [flor de loto significado][1] — even when things get messy or unclear (like this error), there’s usually a clean solution underneath if you take the right steps. [1]: https://tiposdefloress.com/flores-de-loto/
muhammadasad234462
muhammadasad234462 posted this 23 May 2026
An amortization calculator does not change your monthly payment. But it changes everything about how you understand that payment. It replaces guesswork with clarity and anxiety with confidence.
An **[amortization calculator][1]** does not change your monthly payment. But it changes everything about how you understand that payment. It replaces guesswork with clarity and anxiety with confidence. [1]: https://www.amortizationcalculator.us/
morgan3092827
morgan3092827 posted this 08 July 2026
Discover customized industrial ultrasonic cleaning solutions capable of removing stubborn grease, machining oils, polishing compounds, carbon deposits, rust, adhesives, paint residues, and microscopic contaminants from precision components without damaging sensitive surfaces or affecting dimensional accuracy. limpiar filtros campana
Discover customized industrial ultrasonic cleaning solutions capable of removing stubborn grease, machining oils, polishing compounds, carbon deposits, rust, adhesives, paint residues, and microscopic contaminants from precision components without damaging sensitive surfaces or affecting dimensional accuracy. [url=https://iberkleen.com/limpieza-filtros-campana-ultrasonidos/]limpiar filtros campana[/url]
