Add CSS Class and id to images
paolo.mazzagardi
paolo.mazzagardi posted this 18 December 2020
I need to insert a class to several images to use different wordpress plugins.
At the moment it doesn't seem like an implemented feature and I'm forced to use html ....
I need to insert a class to several images to use different wordpress plugins. At the moment it doesn't seem like an implemented feature and I'm forced to use html .... Thanks
11 Comments
Support Team posted this 18 December 2020
Hello Paolo,
This is indeed not implemented feature. We will add it to the Wish List.
Hello Paolo, This is indeed not implemented feature. We will add it to the Wish List. Gina Themler Support
paolo.mazzagardi
Support Team posted this 21 December 2020
Paolo,
I have just thought of another way to work with this.
If you add every image to a different section, you can then use section ID.
For example:
See, the image in my theme is in section with ID section4.
I can then use the following CSS to work with this image:
#section4 img {
Paolo, I have just thought of another way to work with this. If you add every image to a different section, you can then use section ID. For example: !Screenshot-6.png! See, the image in my theme is in section with ID section4. I can then use the following CSS to work with this image: #section4 img { ...} Gina Themler Support
paolo.mazzagardi
paolo.mazzagardi posted this 21 December 2020
Paolo,
For example:
#section4 img {
Hi Gina, unfortunately I have to connect the class to the image otherwise I can't activate the plugins. It's not about simply applying a CSS style ...
thanks anyway for the tip
> Paolo, > > I have just thought of another way to work with this. > If you add every image to a different section, you can then use section ID. > > For example: > ![](https://forumattachments.themler.io/589/43589/Screenshot-6.png) > > See, the image in my theme is in section with ID section4. > I can then use the following CSS to work with this image: > > #section4 img { > ...} > > Gina > Themler Support Hi Gina, unfortunately I have to connect the class to the image otherwise I can't activate the plugins. It's not about simply applying a CSS style ... thanks anyway for the tip
alicemagnet12
alicemagnet12 posted this 04 September 2024
Adding CSS classes and IDs to Geometry Dash Breeze images helps with styling and targeting them specifically in your web design.
Adding CSS classes and IDs to [Geometry Dash Breeze][1] images helps with styling and targeting them specifically in your web design. [1]: https://geometrydashbreeze.org
eja.ge.r.m
eja.ge.r.m posted this 05 July 2025
You're right — WordPress doesn’t natively support bulk-adding classes to images via the editor. For now, using HTML is the best option. If you're also using Image to Text tools, adding classes manually helps target specific images for extraction or plugin functionality.
You're right — WordPress doesn’t natively support bulk-adding classes to images via the editor. For now, using HTML is the best option. If you're also using [Image to Text][1] tools, adding classes manually helps target specific images for extraction or plugin functionality. [1]: https://imagetotext.ltd/
fish27590
fish27590 posted this 18 October 2025
Achieve your certification goals with confidence and ease. Each question in our material is verified by professionals to ensure accuracy and relevance. Our comprehensive CSC1 Questions and Answers set helps you understand real exam concepts and improve performance effectively. Designed for smart learners, our study materials saves time and boosts confidence. With updated content and expert validation, VALID4SURE provides everything you need to pass your CSC1 certification exam successfully on your very first attempt.
Achieve your certification goals with confidence and ease. Each question in our material is verified by professionals to ensure accuracy and relevance. Our comprehensive **[CSC1 Questions and Answers][1]** set helps you understand real exam concepts and improve performance effectively. Designed for smart learners, our study materials saves time and boosts confidence. With updated content and expert validation, **VALID4SURE** provides everything you need to pass your **CSC1 certification** exam successfully on your very first attempt. [1]: https://www.valid4sure.com/CSC1-exam-answers.html
herra teri
herra teri posted this 29 October 2025
I actually tried this feature recently in my site http://aethersx2-apk.com/, and it worked perfectly for me! 😊 I was able to add a custom class to several images without any issues — super handy for integrating with different WordPress plugins. Definitely a time-saver compared to editing the HTML manually.
s8659960
s8659960 posted this 27 November 2025
Certsforce XK0-005 provides reliable study materials designed to help candidates prepare for the CompTIA Linux+ (XK0-005) certification exam. The resources focus on practical Linux administration skills, including system configuration, command-line operations, security, scripting, and troubleshooting. Certsforce offers structured content that aligns with the latest exam objectives, making it easier for learners to review key topics efficiently. Whether you’re strengthening your Linux fundamentals or advancing your IT career, Certsforce XK0-005 materials aim to support confident and effective exam preparation.
70% Discount for Your First Exam!>>>>>>>>>>>>>> https://www.certsforce.com/comptia/exam/xk0-005
Certsforce XK0-005 provides reliable study materials designed to help candidates prepare for the CompTIA Linux+ (XK0-005) certification exam. The resources focus on practical Linux administration skills, including system configuration, command-line operations, security, scripting, and troubleshooting. Certsforce offers structured content that aligns with the latest exam objectives, making it easier for learners to review key topics efficiently. Whether you’re strengthening your Linux fundamentals or advancing your IT career, Certsforce XK0-005 materials aim to support confident and effective exam preparation. **70% Discount for Your First Exam!>>>>>>>>>>>>>> https://www.certsforce.com/comptia/exam/xk0-005**
alphaghostt757
alphaghostt757 posted this 01 December 2025
Ótima dica sobre adicionar classes e IDs às imagens! Para quem precisa calcular medidas e dimensões de forma prática, recomendo conferir a https://calculadoradeescada.vercel.app ela ajuda bastante no planejamento correto da escada e garante mais precisão nos cálculos. Além disso, sempre é bom testar diferentes estilos e configurações para encontrar a melhor solução para cada projeto.
achazx085
achazx085 posted this 3 days ago
Manually editing HTML for every image is a nightmare, so having a clean workflow for custom classes is definitely a win. Speaking of optimizations—if your site covers Android PS2 emulation, it might be worth touching on NetherSX2 ps2 android emulator as well. It’s essentially the community-maintained patch script for AetherSX2 that strips out the ads and restores frontend launching support.
> I actually tried this feature recently in my site http://aethersx2-apk.com/, and it worked perfectly for me! 😊 I was able to add a custom class to several images without any issues — super handy for integrating with different WordPress plugins. Definitely a time-saver compared to editing the HTML manually. Manually editing HTML for every image is a nightmare, so having a clean workflow for custom classes is definitely a win. Speaking of optimizations—if your site covers Android PS2 emulation, it might be worth touching on [NetherSX2 ps2 android emulator][1] as well. It’s essentially the community-maintained patch script for AetherSX2 that strips out the ads and restores frontend launching support. [1]: http://nether-sx2.com/
