Mobile menu accordeon layer
mike77
mike77 posted this 20 December 2020
dear suport engineer,
in my theme the mobile menu accordeon function is not working properly.
It opens behind the content, and content is not sliding down.
I attached the theme, do you know what is wrong?
Mike van den Berg
dear suport engineer, in my theme the mobile menu accordeon function is not working properly. It opens behind the content, and content is not sliding down. I attached the theme, do you know what is wrong? regards, Mike van den Berg
Support Team posted this 22 December 2020
Hello Mike,
1) Switch to mobile view and click for More option under the menu tab.
2) Then select the very top option for "Horizontal Menu" in the dropdown here:
3) Set the width to 90% (it is just an example value) and make sure that Float doesn't have any value (if it is not possible to remove the value, set it to "left":
Themler support
Hello Mike, 1) Switch to mobile view and click for More option under the menu tab. 2) Then select the very top option for "Horizontal Menu" in the dropdown here: !step1.png! 3) Set the width to 90% (it is just an example value) and make sure that Float doesn't have any value (if it is not possible to remove the value, set it to "left": !step2.png! Gina Themler support
mike77
mike77 posted this 22 December 2020
Thanx Gina,
your the best!
Regards, Mike van den Berg
Thanx Gina, your the best! Regards, Mike van den Berg
Thomas Miky
Thomas Miky posted this 4 hours ago
It sounds like there may be a CSS or z-index issue causing the mobile accordion menu to open behind the content instead of pushing it down properly. Responsive design and clean styling are important, especially for websites related to Pubg Mobile name style tools where users expect smooth navigation and fast access to stylish font generators.
It sounds like there may be a CSS or z-index issue causing the mobile accordion menu to open behind the content instead of pushing it down properly. Responsive design and clean styling are important, especially for websites related to [Pubg Mobile name style][1] tools where users expect smooth navigation and fast access to stylish font generators. [1]: https://foontify.com/
