Show correct imaged of theme in "Themes" in cpanel?
dragana
dragana posted this 01 January 2021
I only see the template you get when you first install Themler in cpanel. How can I set the image of how it looks when the template is done?
6 Comments
Support Team posted this 04 January 2021
Hello Dragana,
Usually the theme thumbnail is updated whenever the theme is saved or exported:
If it is not updated on your end, try saving theme as a copy (via File -> Make a copy as) under a bit different name. New copy should have updated thumbnail.
Hello Dragana, Usually the theme thumbnail is updated whenever the theme is saved or exported: !Screenshot-2.png! If it is not updated on your end, try saving theme as a copy (via File -> Make a copy as) under a bit different name. New copy should have updated thumbnail. Gina Themler Support
dragana
dragana posted this 18 February 2021
No it doesn't change. Tried twice now.
Support Team posted this 19 February 2021
You have mentioned cPanel - do you mean thumbnails there or in Themler desktop Theme Management screen shown above?
If on cPanel - unfortunately, we cannot control thumbnail view on hosted websites where the theme is installed, though the thumbnail should still be refreshed in Themler desktop.
Hello, You have mentioned cPanel - do you mean thumbnails there or in Themler desktop Theme Management screen shown above? If on cPanel - unfortunately, we cannot control thumbnail view on hosted websites where the theme is installed, though the thumbnail should still be refreshed in Themler desktop. Sincerely, Nettie
dragana
dragana posted this 19 February 2021
I mean cpanel in wordpress backend.
dragana
dragana posted this 22 February 2021
How do I change the name from Untitled? I'm using Wordpress backend and themler online.
Support Team posted this 09 March 2021
The best way would be to re-export the theme under a different name and then re-install the theme and activate it.
Hello, The best way would be to re-export the theme under a different name and then re-install the theme and activate it. Sincerely, Nettie
