What Joomla version is supported by themler?
Hi, What Joomla version is supported by themler?
Hi, What Joomla version is supported by themler?Hello,
Joomla up to v 3.9 is supported by Themler.
What is with Joomla 4. does you supported them?
What is with Joomla 4. does you supported them?Hello,
We are actively working on developing Themler to support Joomla 4. For now I can say that it will be rather a completely new default Themler theme than a modified existing one because the changes in Joomla are considerable. We will update this topic when any news on the subject appear.
How about updating v523 to be compatible with Joomla 3.10.1?
Currently, it is not compatible, according to the notifications in Joomla admin. The "Themler - default" is compatible. But any other template created from "Themler - default" is considered incompatible.
Are we to "assume" any templates we created from the default "are" compatible?
How about updating v523 to be compatible with Joomla 3.10.1? Currently, it is not compatible, according to the notifications in Joomla admin. The "Themler - default" is compatible. But any other template created from "Themler - default" is considered incompatible. Are we to "assume" any templates we created from the default "are" compatible?It should be compatible, since whether Default theme or not, the code is the same, so any copies of it should work. If they don't, please, share a temporary access in a separate private ticket.
