I'm trying to get Themler to run on a Drupal 8 site by running the downloadable Themler themes and module within drupal.
I've installed and enabled the themler-8.x module and installed the untitled_preview-8.x and untitled-8.x themes.
Within my cPanel file manager I've set the permissions to the folders sites/default/files/, /modules/ & /themes/ as user and group: read, write & execute. I have also done that to all the files and folders within /modules/themler and /themes/ (as far as I can tell).
The theme displays as it should but when I go into the settings for the theme and click Edit theme button I get the following error message.
The website encountered an unexpected error. Please try again later.
Am I setting the permissions correctly or what else do I need to do to get this to work?
I'm trying to get Themler to run on a Drupal 8 site by running the downloadable Themler themes and module within drupal. I've installed and enabled the themler-8.x module and installed the untitled_preview-8.x and untitled-8.x themes. Within my cPanel file manager I've set the permissions to the folders sites/default/files/, /modules/ & /themes/ as user and group: read, write & execute. I have also done that to all the files and folders within /modules/themler and /themes/ (as far as I can tell). The theme displays as it should but when I go into the settings for the theme and click Edit theme button I get the following error message. The website encountered an unexpected error. Please try again later. Am I setting the permissions correctly or what else do I need to do to get this to work?
