Wordpress how to eneble "wp_nav_menu" in only one menu ?
ppukacz
ppukacz posted this 28 January 2021
how to enable "wp_nav_menu" in only one menu ?
needs to disable styles in one menu for the plugin to work. how to do it ?
plugin: menu cart
how to enable "wp_nav_menu" in only one menu ? needs to disable styles in one menu for the plugin to work. how to do it ? plugin: menu cart
Support Team posted this 28 January 2021
It is possible to enable wp_nav_menu only for the theme in general. Check it under wp-admin -> Appearance -> Theme Options:
Try enabling it and see if it works as you need.
Hello, It is possible to enable wp_nav_menu only for the theme in general. Check it under wp-admin -> Appearance -> Theme Options: !Screenshot-2.png! Try enabling it and see if it works as you need. Gina Themler Support
ppukacz
does not work because it turns off all menus.
I just want to disable on one menu
does not work because it turns off all menus. I just want to disable on one menu
ppukacz
ppukacz
ppukacz posted this 29 January 2021
works for all menus.
how to enable only 1 menu?
works for all menus. how to enable only 1 menu?
Support Team posted this 29 January 2021
Unfortunately, it is not possible to turn it off for one menu only.
Maybe, it is possible to style other menus using same plugin that you use?
Unfortunately, it is not possible to turn it off for one menu only. Maybe, it is possible to style other menus using same plugin that you use? Gina Themler Support
