Unable to save Template - account.themler.io redirected you too many times.
eleanor
eleanor posted this 03 February 2021
Please can you help me sort the issue of us not being able to save any of our templates.
I get an error message: account.themler.io redirected you too many times.
Please can you help me sort the issue of us not being able to save any of our templates. I get an error message: account.themler.io redirected you too many times. Thank you
11 Comments
Support Team posted this 03 February 2021
We couldn't reproduce the issue on our end. Looks like the issue is server-related, for example, there is some server firewall, or server plugin or have issu related to http/https protocol.
Also it may have been temporary issue. Is it present at the moment?
Hello, We couldn't reproduce the issue on our end. Looks like the issue is server-related, for example, there is some server firewall, or server plugin or have issu related to http/https protocol. Also it may have been temporary issue. Is it present at the moment? Sincerely, Nettie
eleanor
eleanor posted this 04 February 2021
Well it was still happening but whilst I was trying different sites the template suddenly started saving again.
This was the message I was getting.
I'll get back to you if it reoccurs.
thank you, kind regards
Hi Well it was still happening but whilst I was trying different sites the template suddenly started saving again. This was the message I was getting. !210204-template-not-saving.PNG! I'll get back to you if it reoccurs. thank you, kind regards
Support Team posted this 04 February 2021
Eleanor,
I have reported it to the developers.
Meanwhile, could you please login to themler.io site in Chrome, and then try logging in to Themler Editor again?
Eleanor, I have reported it to the developers. Meanwhile, could you please login to themler.io site in Chrome, and then try logging in to Themler Editor again? Gina Themler Support
eleanor
Hi Gina,
I work in Chrome.
And all my sites are working again, no idea what the issue was but all OK for now, thank you!
Hi Gina, I work in Chrome. And all my sites are working again, no idea what the issue was but all OK for now, thank you!
Ok, good, thank you for letting us know the result.
Ok, good, thank you for letting us know the result. Gina Themler Support
eleanor
eleanor posted this 05 February 2021
Hi Gina
I am again intermittently, having this same issue .
I found your answer from March 2020 to another user:
Sorry for the inconvenience. We have found the problem. It's related to a security update in Google Chrome v80.
1) navigate to:
chrome://appcache-internals
2) navigate to:
1) close Themler
4) start Themler again
I've tried, 1) navigate to:
but my website is not listed so there's nothing to remove.
Do you have any other suggestions as to how to fix this?
Thank you, kind regards
Hi Gina I am again intermittently, having this same issue . I found your answer from March 2020 to another user: *Sorry for the inconvenience. We have found the problem. It's related to a security update in Google Chrome v80. If you are using Google Chrome, try this: 1) navigate to: chrome://appcache-internals find your website and click on 'Remove Item' 2) navigate to: chrome://settings/clearBrowserData select 'Cached images and files ' and click on 'Clear Data' (please don't check other check-boxes). 3) Reload your Themler Editor. Some users have reported that complete re-install of Google Chrome solved the issue. If you are using the Desktop version, then: 1) close Themler 2) open Windows Explorer and type %LocalAppData% in the address bar 3) find & rename Themler directory 4) start Themler again* I've tried, 1) navigate to: chrome://appcache-internals find your website and click on 'Remove Item' but my website is not listed so there's nothing to remove. Do you have any other suggestions as to how to fix this? Thank you, kind regards
Support Team posted this 05 February 2021
If the site is not listed, it means it is not cached. Try to log out from Themler (desktop or any other version you have opened) in case there is still some login active. Then open themler.io site and login there.
Once you are logged in this site, then open Themler editor and check if the account was logged in there as well.
If the site is not listed, it means it is not cached. Try to log out from Themler (desktop or any other version you have opened) in case there is still some login active. Then open themler.io site and login there. Once you are logged in this site, then open Themler editor and check if the account was logged in there as well. Gina Themler Support
eleanor
Hi Gina
That has worked for me! I can save my templates again.
Thank you very much.
kind regards
Hi Gina That has worked for me! I can save my templates again. Thank you very much. kind regards
rahanmazhar19
rahanmazhar19 posted this 24 September 2024
It sounds frustrating to encounter that error with saving templates. You might want to try clearing your browser cache or using a different browser to see if that resolves the issue. Meanwhile, if you’re interested in some great templates for your projects, the ical ar capcut template could be worth checking out. Hope you find a solution soon!
It sounds frustrating to encounter that error with saving templates. You might want to try clearing your browser cache or using a different browser to see if that resolves the issue. Meanwhile, if you’re interested in some great templates for your projects, the [ical ar capcut template][1] could be worth checking out. Hope you find a solution soon! [1]: https://capcuttemplatebox.com/ical-capcut-template/
xvanwormerson7
xvanwormerson7 posted this 19 February 2025
A well-detailed post that delivered knowledge in a structured way. The logical explanations ensured clarity and better understanding.
PTCL Smart TV Channels
A well-detailed post that delivered knowledge in a structured way. The logical explanations ensured clarity and better understanding. [PTCL Smart TV Channels][1] [1]: https://sekho.com.pk/technology/ptcl-smart-tv-channels-list-in-pakistan/
bodixih555
bodixih555 posted this 08 June 2025
You have the best post or the users like to know about unable to save Template - account.themler redirected you too many times and these are the big issues we are acing. When I got the driveway cleaning i saw the best professionals who deal with it to provide us with satisfactory results.
You have the best post or the users like to know about unable to save Template - account.themler redirected you too many times and these are the big issues we are acing. When I got the [driveway cleaning][1] i saw the best professionals who deal with it to provide us with satisfactory results. [1]: https://pressurecleaningrobina.com.au
