Content restored to a previous version
desarrollo8
desarrollo8 posted this 11 February 2021
I was editing a section of my web and I forgot to save.
Then, I opened a new window and the old one closes, losing my changes.
When the new window opened, not only my last changes disappeared, but also all the content was restored to another backup version. I don't know what to do to restore my changes.
Hi, I was editing a section of my web and I forgot to save. Then, I opened a new window and the old one closes, losing my changes. When the new window opened, not only my last changes disappeared, but also all the content was restored to another backup version. I don't know what to do to restore my changes.
Support Team posted this 11 February 2021
Did you work in Themer dekstop or on your website?
Hello, Did you work in Themer dekstop or on your website? Sincerely, Nettie
desarrollo8
In my website (a wordpress).
If you need any other information let me know.
Thank you.
In my website (a wordpress). If you need any other information let me know. Thank you.
Did you use some backup function in CMS backend? Because if you use some theme backup from Themler, content is not touched, only theme (unless you re-import content from the backup). Unfortunately, there is no other way to recover a theme than to use its backup (either stored somewhere locally or created by Themler in Wordpress - for example, when you update a theme).
We are not sure about what behaviour can be expected if some CMS backup function is used.
Hello, Did you use some backup function in CMS backend? Because if you use some theme backup from Themler, content is not touched, only theme (unless you re-import content from the backup). Unfortunately, there is no other way to recover a theme than to use its backup (either stored somewhere locally or created by Themler in Wordpress - for example, when you update a theme). We are not sure about what behaviour can be expected if some CMS backup function is used. Sincerely, Nettie
