jQuery update and Wordpress 5.7
colombimarco7
colombimarco7 posted this 17 February 2021
Will Themler be compatible with wordpress 5.7? And also compatible with the new major jQuery update?
Hi, Will Themler be compatible with wordpress 5.7? And also compatible with the new major jQuery update? Thank you
8 Comments
Support Team posted this 21 February 2021
Hello Marco,
We will test Themler with WP 5.7 next week and if any compatibility updates are required, we will work on those.
Hello Marco, We will test Themler with WP 5.7 next week and if any compatibility updates are required, we will work on those. Gina Themler Support
colombimarco7
colombimarco7 posted this 10 March 2021
can I upgrade the site to wordpress 5.7? is themler compatible?
Hi, can I upgrade the site to wordpress 5.7? is themler compatible? Thanks
Support Team posted this 11 March 2021
Hello Mark,
No major issues are found so far, but we still recommend to make a backup before upgrading to WP 5.7.
Hello Mark, No major issues are found so far, but we still recommend to make a backup before upgrading to WP 5.7. Gina Themler Support
Sinergia Innovaciones
Sinergia Innovaciones posted this 23 June 2021
I´ve updated to wordpress 5.7.2, and now I don't have Themler tools, neither Theme builder and I can't make modifications in the theme because the error message is "not allowed to modify". I already checked health site wordpress but I still can't do use themler. .I also can't run the Windows 10 PC tool even though I already ran the compatability mode. Please help me. Thanks
Hi, I´ve updated to wordpress 5.7.2, and now I don't have Themler tools, neither Theme builder and I can't make modifications in the theme because the error message is "not allowed to modify". I already checked health site wordpress but I still can't do use themler. .I also can't run the Windows 10 PC tool even though I already ran the compatability mode. Please help me. Thanks
Support Team posted this 24 June 2021
Please make sure to enable "Include Themler" option on export. Looks like it was disabled the other time.
As for Themler for Windows, please try the following:
Hello, Please make sure to enable "Include Themler" option on export. Looks like it was disabled the other time. As for Themler for Windows, please try the following: 1. Backup all theme folders somewhere on your computer if there are any. The path is shown in the Theme Management screen after selecting some CMS, for example, `C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\wordpress`. 2. Uninstall Themler completely and also check the box for "Remove all CMS content". 3. Check if the following folders are still present: C:\Program Files (x86)\Themler C:\ProgramData\Themler 4. If they exist, remove them. 5. Reboot the machine after uninstalling Themler, so that all Themler services are removed for sure. 6. Temporarily disable antivirus and firewall. 7. Download latest version of Themler for Windows from themler.io, install it and try to start with Themler for any CMS and create a theme. Please let us know the result. Sincerely, Nettie
Sinergia Innovaciones posted this 25 June 2021
Thanks four your answer. I could edit the themler template from wordpress in the past, but then I couldn't, Themler tools didn't appear anymore either.
But well, I was able to install the Themler application on a different computer, with that I was able to make the changes in the template and export again.
Greetings
Diana
Hi, Thanks four your answer. I could edit the themler template from wordpress in the past, but then I couldn't, Themler tools didn't appear anymore either. But well, I was able to install the Themler application on a different computer, with that I was able to make the changes in the template and export again. Greetings Diana
Support Team posted this 28 June 2021
Diana, thanks for letting us know. Please feel free to contact us in any other case..
Diana, thanks for letting us know. Please feel free to contact us in any other case.. Sincerely, Nettie
adithiups
adithiups posted this 30 June 2021
