Full Width Using Gutenberg with Themler
ike
ike posted this 19 February 2021
I am using Themler for my theme package so that I can manipulate the Header and the Footer area, and then set some of the fonts, and other basic features. I am using Gutenberg to edit everything between the Header and the Footer, I am setting the theme to have a box width, however, I have rows that I would like to have full width to the edge of the page. I am unable to figure out how to do this. There are discussions on the WordPress sections that there must be full-width assets in the functions .php file. Can anyone tell me if I am on the right track here or not, has anyone tried to accomplish this? Other thoughts out there from anyone?
Support Team posted this 19 February 2021
Do you need to have Full Width only on a specific page?
If so, you can try creating new Page template in Themler, change the content width to Fluid and check all other settings to match this design (like page width, any extra margins or paddings on the sides). Then this template can be assigned to that specific page you need.
Hello, Do you need to have Full Width only on a specific page? If so, you can try creating new Page template in Themler, change the content width to Fluid and check all other settings to match this design (like page width, any extra margins or paddings on the sides). Then this template can be assigned to that specific page you need. Gina Themler Support
ike
ike posted this 20 February 2021
No it's on multiple pages where i would just put a section or a row in that would make it full width. So for instance before I was using WPBakery, and on a row, I could add a column, and in the setting make it full width, or box. This would override the width settings on the template so it didn't mess up the other 50 pages, or posts. So if I changed the template, all those other pages would still be what the new template was, only those columns would have the override, I'm trying to find a way to make that work for Gutenberg, or at least implement the path that the WordPress community put out there which was this
https://weblines.com.au/gutenberg-blocks-wide-alignment-full-width/
If someone can give me information of how to implement this in Themler, and make it work, and make it so when I update the theme I don't have to go back and reinstall this each time, it would be greatly helpful.
Ike
No it's on multiple pages where i would just put a section or a row in that would make it full width. So for instance before I was using WPBakery, and on a row, I could add a column, and in the setting make it full width, or box. This would override the width settings on the template so it didn't mess up the other 50 pages, or posts. So if I changed the template, all those other pages would still be what the new template was, only those columns would have the override, I'm trying to find a way to make that work for Gutenberg, or at least implement the path that the WordPress community put out there which was this https://weblines.com.au/gutenberg-blocks-wide-alignment-full-width/ If someone can give me information of how to implement this in Themler, and make it work, and make it so when I update the theme I don't have to go back and reinstall this each time, it would be greatly helpful. Ike
Support Team posted this 22 February 2021
If I were using Themler only, I would have taken the advantage of custom templates in it. I.e. create new Page template with full (or block) width and then assign this specific template to the pages needed.
See more details here: https://answers.themler.io/articles/9466/how-to-create-and-use-custom-templates
This would though mean that when you install new theme, it must contain custom template as well and you would need to assign it to those pages again.
If we go with WP Gutenberg rules, we can try the following (this wasn't tested though):
1) add this code to Home -> Setting -> CMS Code field:
 * Register support for Gutenberg wide images in your theme
function mytheme_setup() {
  add_theme_support( 'align-wide' );
add_action( 'after_setup_theme', 'mytheme_setup' );
2) Add this code to Home -> Settings -> Additional CSS:
  .entry-content .alignwide {
        margin-left  : -80px;
        margin-right : -80px;
    .entry-content .alignfull {
        margin-left  : calc( -100vw / 2 + 100% / 2 );
        margin-right : calc( -100vw / 2 + 100% / 2 );
        max-width    : 100vw;
    .alignfull img {
        width: 100vw;
This code is taken from the article you referred to, so you can change the values for the CSS code in it.
If I were using Themler only, I would have taken the advantage of custom templates in it. I.e. create new Page template with full (or block) width and then assign this specific template to the pages needed. See more details here: https://answers.themler.io/articles/9466/how-to-create-and-use-custom-templates This would though mean that when you install new theme, it must contain custom template as well and you would need to assign it to those pages again. If we go with WP Gutenberg rules, we can try the following (this wasn't tested though): 1) add this code to Home -> Setting -> CMS Code field: /** * Register support for Gutenberg wide images in your theme */ function mytheme_setup() { add_theme_support( 'align-wide' ); } add_action( 'after_setup_theme', 'mytheme_setup' ); 2) Add this code to Home -> Settings -> Additional CSS: .entry-content .alignwide { margin-left : -80px; margin-right : -80px; } .entry-content .alignfull { margin-left : calc( -100vw / 2 + 100% / 2 ); margin-right : calc( -100vw / 2 + 100% / 2 ); max-width : 100vw; } .alignfull img { width: 100vw; } This code is taken from the article you referred to, so you can change the values for the CSS code in it. Gina Themler Support
alexarafatonline
alexarafatonline posted this 26 February 2026
You’re on the right track. In Themler themes, full-width rows usually need theme support for full-width Gutenberg blocks or custom CSS. Some themes require adding full-width container classes in functions.php, but often you can simply enable full-width alignment in Gutenberg block settings. I faced something similar while organizing my site, and it felt like solving a puzzle. By the way, it reminds me of how fabbalancechecking can sometimes confuse users—Checking your FAB balance shouldn’t be confusing, yet many UAE customers still struggle with app logins, SMS formats, and prepaid payroll cards. In 2026, you can do a FAB balance check online, through apps, SMS (FAB balance check 2121), ATM, or Payit and Ratibi tools if you pick the right method.
You’re on the right track. In Themler themes, full-width rows usually need theme support for full-width Gutenberg blocks or custom CSS. Some themes require adding full-width container classes in functions.php, but often you can simply enable full-width alignment in Gutenberg block settings. I faced something similar while organizing my site, and it felt like solving a puzzle. By the way, it reminds me of how [fabbalancechecking][1] can sometimes confuse users—Checking your FAB balance shouldn’t be confusing, yet many UAE customers still struggle with app logins, SMS formats, and prepaid payroll cards. In 2026, you can do a FAB balance check online, through apps, SMS (FAB balance check 2121), ATM, or Payit and Ratibi tools if you pick the right method. [1]: https://fabbalancechecking.com/
radatiy248
radatiy248 posted this 26 March 2026
Get ready for a pulse-pounding adventure in Geometry Dash World! Designed by RobTop Games, the game delivers intense action, stunning neon visuals, and electrifying music tracks. With each level increasing in difficulty, only the most focused players can conquer every challenge and unlock all rewards.
Get ready for a pulse-pounding adventure in [Geometry Dash World][1]! Designed by RobTop Games, the game delivers intense action, stunning neon visuals, and electrifying music tracks. With each level increasing in difficulty, only the most focused players can conquer every challenge and unlock all rewards. [1]: https://geometryworld.io
