Hello Community,
Unfortunately I can no open the template and got the following error. What can I do here?
Warning: Invalid argument supplied for foreach() in /XXXXX/library/Designer/LogFormatter.php on line 8
[PHP_ERROR]{"message":"\n\nOS: Linux info 3.0 #1337 SMP Tue Jan 01 00:00:00 CEST 2000 all GNU/Linux\nPHP: 7.4.10\nerror handler: Array and string offset access syntax with curly braces is deprecated\nArray\n(\n [file] => /XXXXX/libraries/vendor/composer/../joomla/filesystem/src/Path.php\n)\n Callstack: \n -> include()\n -> Composer\Autoload\includeFile('/XXXXXXX/libraries/vendor/composer/../joomla/filesystem/src/Path.php')\n -> Composer\Autoload\ClassLoader::loadClass('Joomla\Filesystem\Path')\n -> JClassLoader::loadClass('Joomla\Filesystem\Path')\n -> spl_autoload_call('Joomla\Filesystem\Path')\n -> Joomla\Filesystem\Folder::create('/
XXXXX
/templates/XXXXX/plugins/')\n -> Joomla\Archive\Zip::extractNative('/XXXXX/templates/XXXXX/plugins/button.zip', '/XXXXX/templates/XXXXX/plugins/')\n -> Joomla\Archive\Zip::extract('/XXXXX/templates/XXXXX/plugins/button.zip', '/XXXXX/templates/XXXXX/plugins/')\n -> Joomla\Archive\Archive::extract('/XXXXX/templates/XXXXX/plugins/button.zip', '/XXXXX/templates/XXXXX/plugins/')\n -> JArchive::extract('/XXXXX/templates/XXXXX/plugins/button.zip', '/XXXXX/templates/XXXXX/plugins/')\n -> JFormFieldPlugins::_checkPlugins('XXXXX')\n -> JFormFieldPlugins::getInput()\n -> Joomla\CMS\Form\FormField::renderField()\n -> include('/XXXXX/layouts/joomla/edit/fieldset.php')\n -> Joomla\CMS\Layout\FileLayout::render(TemplatesViewStyle(...) { ... })\n -> Joomla\CMS\Layout\LayoutHelper::render('joomla.edit.fieldset', TemplatesViewStyle(...) { ... })\n -> include('/XXXXX/administrator/components/com_templates/views/style/tmpl/edit....')\n -> Joomla\CMS\MVC\View\HtmlView::loadTemplate(NULL)\n -> Joomla\CMS\MVC\View\HtmlView::display(NULL)\n -> TemplatesViewStyle::display()\n -> Joomla\CMS\MVC\Controller\BaseController::display()\n -> TemplatesController::display()\n -> Joomla\CMS\MVC\Controller\BaseController::execute('')\n -> require_once('/XXXXX/administrator/components/com_templates/templates.php')\n -> Joomla\CMS\Component\ComponentHelper::executeComponent('/XXXXX/administrator/components/com_templates/templates.php')\n -> Joomla\CMS\Component\ComponentHelper::renderComponent('com_templates')\n -> Joomla\CMS\Application\AdministratorApplication::dispatch()\n -> Joomla\CMS\Application\AdministratorApplication::doExecute()\n -> Joomla\CMS\Application\CMSApplication::execute()\n\n\n","type":"E_DEPRECATED","file":"/XXXXX/libraries/vendor/joomla/filesystem/src/Path.php","line":153}[PHP_ERROR]
Does anyone know this problem and can help?
Hello Community, Unfortunately I can no open the template and got the following error. What can I do here? Warning: Invalid argument supplied for foreach() in /XXXXX/library/Designer/LogFormatter.php on line 8 [PHP_ERROR]{"message":"\n\nOS: Linux info 3.0 #1337 SMP Tue Jan 01 00:00:00 CEST 2000 all GNU/Linux\nPHP: 7.4.10\nerror handler: Array and string offset access syntax with curly braces is deprecated\nArray\n(\n [file] => /XXXXX/libraries/vendor/composer/../joomla/filesystem/src/Path.php\n)\n Callstack: \n -> include()\n -> Composer\Autoload\includeFile('/XXXXXXX/libraries/vendor/composer/../joomla/filesystem/src/Path.php')\n -> Composer\Autoload\ClassLoader::loadClass('Joomla\\Filesystem\\Path')\n -> JClassLoader::loadClass('Joomla\\Filesystem\\Path')\n -> spl_autoload_call('Joomla\\Filesystem\\Path')\n -> Joomla\Filesystem\Folder::create('/ XXXXX ------------------------------------- /templates/XXXXX/plugins/')\n -> Joomla\Archive\Zip::extractNative('/XXXXX/templates/XXXXX/plugins/button.zip', '/XXXXX/templates/XXXXX/plugins/')\n -> Joomla\Archive\Zip::extract('/XXXXX/templates/XXXXX/plugins/button.zip', '/XXXXX/templates/XXXXX/plugins/')\n -> Joomla\Archive\Archive::extract('/XXXXX/templates/XXXXX/plugins/button.zip', '/XXXXX/templates/XXXXX/plugins/')\n -> JArchive::extract('/XXXXX/templates/XXXXX/plugins/button.zip', '/XXXXX/templates/XXXXX/plugins/')\n -> JFormFieldPlugins::_checkPlugins('XXXXX')\n -> JFormFieldPlugins::getInput()\n -> Joomla\CMS\Form\FormField::renderField()\n -> include('/XXXXX/layouts/joomla/edit/fieldset.php')\n -> Joomla\CMS\Layout\FileLayout::render(TemplatesViewStyle(...) { ... })\n -> Joomla\CMS\Layout\LayoutHelper::render('joomla.edit.fieldset', TemplatesViewStyle(...) { ... })\n -> include('/XXXXX/administrator/components/com_templates/views/style/tmpl/edit....')\n -> Joomla\CMS\MVC\View\HtmlView::loadTemplate(NULL)\n -> Joomla\CMS\MVC\View\HtmlView::display(NULL)\n -> TemplatesViewStyle::display()\n -> Joomla\CMS\MVC\Controller\BaseController::display()\n -> TemplatesController::display()\n -> Joomla\CMS\MVC\Controller\BaseController::execute('')\n -> require_once('/XXXXX/administrator/components/com_templates/templates.php')\n -> Joomla\CMS\Component\ComponentHelper::executeComponent('/XXXXX/administrator/components/com_templates/templates.php')\n -> Joomla\CMS\Component\ComponentHelper::renderComponent('com_templates')\n -> Joomla\CMS\Application\AdministratorApplication::dispatch()\n -> Joomla\CMS\Application\AdministratorApplication::doExecute()\n -> Joomla\CMS\Application\CMSApplication::execute()\n\n\n","type":"E_DEPRECATED","file":"/XXXXX/libraries/vendor/joomla/filesystem/src/Path.php","line":153}[PHP_ERROR] Does anyone know this problem and can help?
