Conflict with Nicepage WordPress plugin
miroslav.cihlo
miroslav.cihlo posted this 08 March 2021
Hi all,
I would like to ask you once again for information whether you have solved my issue with conflict between by Themler made theme and Nicepage WordPress plugin which leads to disruption in some functions ( like animations set by Themler) .
Link to previous question is here:
https://answers.themler.io/questions/207081/animations-do-not-work-well
Thank you in advance
Best regards
Mira
Hi all, I would like to ask you once again for information whether you have solved my issue with conflict between by Themler made theme and Nicepage WordPress plugin which leads to disruption in some functions ( like animations set by Themler) . Link to previous question is here: https://answers.themler.io/questions/207081/animations-do-not-work-well Thank you in advance Best regards Mira
10 Comments
miroslav.cihlo
miroslav.cihlo posted this 09 March 2021
I wrote about conflict between Themler theme and Nicepage WordPress plugin not Nicepage alone. I cannot see any contraindication in usage Nicepage WordPress plugin in a wordpress theme made by Themler. But there is a conflict in functions which I would like to solve.
Support Team posted this 16 March 2021
Hello Miroslav,
As mentioned in your initial thread on this, the issue is reported to the developers through Nicepage support.
Themler support
Hello Miroslav, As mentioned in your initial thread on this, the issue is reported to the developers through Nicepage support. Gina Themler support
Michael Casares
Michael Casares posted this 18 March 2021
Nicepage plugin for WordPress is a content builder plugin. But in some cases the conflicts are possible.
**Nicepage** plugin for WordPress is a content builder plugin. But in some cases the conflicts are possible.
alexarafatonline
alexarafatonline posted this 06 August 2025
Hi, just checking in to see if there's been any update regarding the conflict between the Themler theme and the Nicepage plugin—especially the animation issues I mentioned earlier (linked here: https://answers.themler.io/questions/207081/animations-do-not-work-well).
While waiting for a fix, I’ve been distracting myself by revisiting old PS2 classics like Grand Theft Auto and God of War. I don’t have a console anymore, but found a great workaround using the AetherSX2 APK — a free Android PS2 emulator that lets you play all those nostalgic games right on your phone or PC. Thought I'd share in case anyone else here is also into retro gaming while dealing with theme/plugin bugs.
Hi, just checking in to see if there's been any update regarding the conflict between the Themler theme and the Nicepage plugin—especially the animation issues I mentioned earlier (linked here: https://answers.themler.io/questions/207081/animations-do-not-work-well). While waiting for a fix, I’ve been distracting myself by revisiting old PS2 classics like Grand Theft Auto and God of War. I don’t have a console anymore, but found a great workaround using the [AetherSX2 APK][1] — a free Android PS2 emulator that lets you play all those nostalgic games right on your phone or PC. Thought I'd share in case anyone else here is also into retro gaming while dealing with theme/plugin bugs. [1]: https://aethersx2apk.net/
alexarafatonline
alexarafatonline posted this 19 December 2025
I ran into a similar situation trying to fix conflicts between plugins and themes. It reminded me of when I first tried setting up AetherSX2 to play PS2 games—I had everything installed and ready, but nothing worked until I got the AetherSX2 PS2 BIOS download. Without it, the emulator wouldn’t even start, just like some theme features won’t function without proper plugin compatibility. Hope this helps guide your troubleshooting!
I ran into a similar situation trying to fix conflicts between plugins and themes. It reminded me of when I first tried setting up AetherSX2 to play PS2 games—I had everything installed and ready, but nothing worked until I got the [AetherSX2 PS2 BIOS download][1]. Without it, the emulator wouldn’t even start, just like some theme features won’t function without proper plugin compatibility. Hope this helps guide your troubleshooting! [1]: https://aethersxx2apk.com/aethersx2-bios-2/
aliciacole9900
aliciacole9900 posted this 07 January 2026
I ran into a similar situation trying to fix conflicts between plugins and themes. It reminded me of when I first tried setting up AetherSX2 to play PS2 games—I had everything installed and ready, but nothing worked until I got the Experience the thrill of the city with GTA 5 Mobile, offering stunning graphics and immersive gameplay right on your device.
I ran into a similar situation trying to fix conflicts between plugins and themes. It reminded me of when I first tried setting up AetherSX2 to play PS2 games—I had everything installed and ready, but nothing worked until I got the Experience the thrill of the city with [GTA 5 Mobile][1], offering stunning graphics and immersive gameplay right on your device. [1]: https://gta5spots.com/
gtasaapks
gtasaapks posted this 09 January 2026
Plugin and theme conflicts like this are unfortunately quite common in WordPress, especially when both tools inject their own scripts for animations or layouts. In similar cases, I’ve found that isolating script loading or testing on a clean install helps identify the real cause faster.
While waiting for official fixes, I usually step away and relax with games like gta sa apk or explore optimized mobile setups such as gta 5 mobile obb, which at least work smoothly without compatibility headaches.
Plugin and theme conflicts like this are unfortunately quite common in WordPress, especially when both tools inject their own scripts for animations or layouts. In similar cases, I’ve found that isolating script loading or testing on a clean install helps identify the real cause faster. While waiting for official fixes, I usually step away and relax with games like [gta sa apk][1] or explore optimized mobile setups such as [gta 5 mobile obb][2], which at least work smoothly without compatibility headaches. [1]: https://gtasaapks.com/ [2]: https://gta5mobilez.com/
gtasaapks
This site looks like a useful place to get information about the Parivahan Sewa transport services in India — things like driving licence applications, vehicle registration, e-challan payments, and checking RC/DL status online are all explained in one spot, which can save a lot of time compared to visiting an RTO office in person.
This site looks like a useful place to get information about the [Parivahan Sewa][1] transport services in India — things like driving licence applications, vehicle registration, e-challan payments, and checking RC/DL status online are all explained in one spot, which can save a lot of time compared to visiting an RTO office in person. [1]: https://parivahansawa.com/
csj06091
csj06091 posted this 10 January 2026
This is truly excellent information, providing everyone with the information they need. All the information you've posted seems to be enough to provide positive energy to many. I'd like to thank you for all the hard work you've put into this site. I admire your dedication to sharing knowledge and fostering positive change. I look forward to seeing more from you.
For your information, I'd like to share information on massage techniques that can help relieve neck and shoulder pain caused by prolonged sitting, and I'd like to share information on a website specializing in job postings for massage therapists. 스웨디시구인
This is truly excellent information, providing everyone with the information they need. All the information you've posted seems to be enough to provide positive energy to many. I'd like to thank you for all the hard work you've put into this site. I admire your dedication to sharing knowledge and fostering positive change. I look forward to seeing more from you. For your information, I'd like to share information on massage techniques that can help relieve neck and shoulder pain caused by prolonged sitting, and I'd like to share information on a website specializing in job postings for massage therapists. [스웨디시구인][1] [1]: https://massagequeen.co.kr/
verifybtc11
verifybtc11 posted this 10 January 2026
Conflicts with the Nicepage WordPress plugin usually occur when it clashes with a theme, another plugin, or certain WordPress core features. These issues can show up as broken layouts, editor loading errors, slow performance, or styles not displaying or Read the article correctly on the front end. In many cases, the conflict is caused by aggressive caching, minification, or JavaScript optimization plugins that interfere with Nicepage’s scripts and CSS.
Conflicts with the Nicepage WordPress plugin usually occur when it clashes with a theme, another plugin, or certain WordPress core features. These issues can show up as broken layouts, editor loading errors, slow performance, or styles not displaying or [Read the article][1] correctly on the front end. In many cases, the conflict is caused by aggressive caching, minification, or JavaScript optimization plugins that interfere with Nicepage’s scripts and CSS. [1]: https://bitlifeunblockedgames.com/
