Joomla in Themler desktop gives "page not found"
Seppe
Seppe posted this 10 March 2021
Good morning
Every couple weeks, it's impossible to use Themler desktop.
I only use the Joomla section.
For every existing template in Themler Desktop, I get the standard error screen: "page not found".
If I import an existing template, I get the standard error screen: "page not found".
If I create a new template in Themler Desktop, I get the standard error screen: "page not found".
There seems no other possible solution to deinstall the full Themler Desktop, and reinstall everything again.
I don't know if the existing templates I made already will work in the new installation.
When will there be a descent solution for this matter?
After a couple years of using Themler, I start to get irritated with this kinds of troubles.
Good morning Every couple weeks, it's impossible to use Themler desktop. I only use the Joomla section. For every existing template in Themler Desktop, I get the standard error screen: "page not found". If I import an existing template, I get the standard error screen: "page not found". If I create a new template in Themler Desktop, I get the standard error screen: "page not found". There seems no other possible solution to deinstall the full Themler Desktop, and reinstall everything again. I don't know if the existing templates I made already will work in the new installation. When will there be a descent solution for this matter? After a couple years of using Themler, I start to get irritated with this kinds of troubles.
6 Comments
Support Team posted this 10 March 2021
Sorry for the inconvenience. Looks like for some reason there was no item selected as Front page in Joomla admin. I would recommend to check this and re-set the item, if necessary, if the issue appears once again.
Hello, Sorry for the inconvenience. Looks like for some reason there was no item selected as Front page in Joomla admin. I would recommend to check this and re-set the item, if necessary, if the issue appears once again. Sincerely, Nettie
Seppe
Everytime I start Themler, select Joomla, and then want to "create new template" I have this.
Even when I start the "untitled", the default template, the same issue is there.
I guess I re-installed Themler for the 57861'd time... It will work again for a couple of weeks.
Only when I now create a default template, then upload it to the server, it continue working.
So I only need to do this once, meaning that the Themler Desktop is completly useless....
Everytime I start Themler, select Joomla, and then want to "create new template" I have this. Even when I start the "untitled", the default template, the same issue is there. I guess I re-installed Themler for the 57861'd time... It will work again for a couple of weeks. Only when I now create a default template, then upload it to the server, it continue working. So I only need to do this once, meaning that the Themler Desktop is completly useless....
Once more sorry about this. I assume you have already tried the way above with assigning the menu item, right? We can also recommend to install Joomla on some localhost and use Themler theme there. An additional bonus will be that you can use different CMS content for different websites, unlike it is in Themler desktop.
Hello, Once more sorry about this. I assume you have already tried the way above with assigning the menu item, right? We can also recommend to install Joomla on some localhost and use Themler theme there. An additional bonus will be that you can use different CMS content for different websites, unlike it is in Themler desktop. Sincerely, Nettie
Seppe
Seppe posted this 11 March 2021
Good morning
That's why I said, when I have a clean install of Themler desktop, I need to export the current template and use that on the servers.
So desktop-version becomes useless
Good morning That's why I said, when I have a clean install of Themler desktop, I need to export the current template and use that on the servers. So desktop-version becomes useless
Support Team posted this 12 March 2021
If the issue happens again, try this:
1) close Themler
4) start Themler again
If the issue happens again, try this: 1) close Themler 2) open Windows Explorer and type %LocalAppData% in the address bar 3) find & rename Themler directory 4) start Themler again Gina
Michael Casares
Michael Casares posted this 14 March 2021
Good morning
Hey, Seppe
Thanks for sharing your suggestion.
> Good morning > > That's why I said, when I have a clean install of Themler desktop, I need to export the current template and use that on the servers. > > So desktop-version becomes useless Hey, **Seppe** Thanks for sharing your suggestion.
