Themler PRO online version issues Joomla 3.4.3
alexfr79
alexfr79 posted this 16 August 2015
CMS : Joomla 3.4.3
I think there are several issues :
pagination in search result list
can you check pagination_list_render_common.php please ?
problem with breadcrumbs. It's only in the home page.
Generated external social links :
www.facebook.com instead of http://www.facebook.com
Is online Themler still in beta version ?
Alexandre from France
Hello CMS : Joomla 3.4.3 I think there are several issues : pagination in search result list can you check **pagination_list_render_common.php** please ? problem with breadcrumbs. It's only in the home page. Generated external social links : www.facebook.com instead of http://www.facebook.com Is online Themler still in beta version ? Regards Alexandre from France
35 Comments
Support Team posted this 18 August 2015
Sorry for the delay. Our developers are looking now into the issues. We'll let you know as soon as there is a solution.
Hi, Sorry for the delay. Our developers are looking now into the issues. We'll let you know as soon as there is a solution. Sincerely, Hella BillionDigital Team
Could you please clarify your issue a little bit.
  1. I'm not sure what is wrong with pagination. It worked just fine for me.
  2. Actually, breadcrumbs control is not supposed to be shown on your Home page.
  3. I wasn't able to reproduce your issue with Icon link control. Please have a look at my screenshot:
We're looking forward to receive some more details from your so we can try to help you.
Ivan
Hi, Could you please clarify your issue a little bit. 1. I'm not sure what is wrong with pagination. It worked just fine for me. 2. Actually, breadcrumbs control is not supposed to be shown on your Home page. 3. I wasn't able to reproduce your issue with **Icon link** control. Please have a look at my screenshot: !facebook.png! We're looking forward to receive some more details from your so we can try to help you. Thanks, Ivan
alexfr79
alexfr79 posted this 19 August 2015
Sorry for the delay
1 : pagination issue :
Please, have a look at :
http://www.afr2i.com/demo/index.php/utiliser-joomla/utiliser-extensions/composants/composant-contenu/articles-categorie-liste
and
http://www.afr2i.com/demo/index.php/utiliser-joomla/utiliser-extensions/composants/composant-recherche/recherche-resultats?searchword=joomla&searchphrase=all
Please check pagination_list_render_common.php
2 : Breadcrumb : Please show me the way how to implement this control
3 : Icon link : OK
Best regards
Hi Sorry for the delay 1 : pagination issue : Please, have a look at : http://www.afr2i.com/demo/index.php/utiliser-joomla/utiliser-extensions/composants/composant-contenu/articles-categorie-liste and http://www.afr2i.com/demo/index.php/utiliser-joomla/utiliser-extensions/composants/composant-recherche/recherche-resultats?searchword=joomla&searchphrase=all Please check **pagination_list_render_common.php** 2 : Breadcrumb : **Please show me the way how to implement this control** 3 : Icon link : **OK** Best regards Alexandre from France
Support Team posted this 19 August 2015
  1. Thanks for the links, I'll forward them to the development team.
  2. Breadcrumbs can not be shown in the home page as the home page is the root page. To make the breadcrumbs appear on other pages please make sure that the breadcrumbs control is placed in the page template. By the default it is inserted in the top sidebar, click on the breadcrumbs, navigate to the corresponding sidebar options and switch off the Hide if position is empty option. The other way is to drag the breadcrumbs control out of the sidebar.
    Do not forget to check that the breadcrumbs module is positioned in the breadcrumbs position in your Joomla back end.
Hi, 1. Thanks for the links, I'll forward them to the development team. 2. Breadcrumbs can not be shown in the home page as the home page is the root page. To make the breadcrumbs appear on other pages please make sure that the breadcrumbs control is placed in the page template. By the default it is inserted in the top sidebar, click on the breadcrumbs, navigate to the corresponding sidebar options and switch off the Hide if position is empty option. The other way is to drag the breadcrumbs control out of the sidebar. Do not forget to check that the breadcrumbs module is positioned in the breadcrumbs position in your Joomla back end. Sincerely, Hella BillionDigital Team
Support Team posted this 20 August 2015
Could you please provide an access to your Joomla back end as our developers can not reproduce the issue with the pagination.
Hi, Could you please provide an access to your Joomla back end as our developers can not reproduce the issue with the pagination. Sincerely, Hella BillionDigital Team
alexfr79
alexfr79 posted this 20 August 2015
hi,
Ok, give me an email address and I'll give you an access
best regards
hi, Ok, give me an email address and I'll give you an access best regards Alexandre from France
support@billiondigital.com
Hi, support@billiondigital.com Thank you, Olivia
Please stand by.
Thank you, Please stand by.
alexfr79
ok
thanx
ok thanx
ajkosan
ajkosan posted this 22 August 2015
Hello.
I also have pagination issue as alexfr79,
Please do so.
Also If I want to translate pagination in own language then I have to translated in this file (pagination_list_render_common.php). But what if site is multilingual? Then this is not ok!!!
Waiting for your fix.
Best regards,
Vito
Hello. I also have pagination issue as alexfr79, > Please check pagination_list_render_common.php Please do so. Also If I want to translate pagination in own language then I have to translated in this file (pagination_list_render_common.php). But what if site is multilingual? Then this is not ok!!! Waiting for your fix. Best regards, Vito
Support Team posted this 25 August 2015
Hello Alexandre and Vito ,
the reported issue with pagination has been resolved in the last Themler update. Please open the theme in Themler and click Update icon to update the theme. Then save it /apply to Joomla.
Hello Alexandre and Vito , the reported issue with pagination has been resolved in the last Themler update. Please open the theme in Themler and click Update icon to update the theme. Then save it /apply to Joomla. regards, Aileen
alexfr79
alexfr79 posted this 25 August 2015
Hi Aileen
Thanx
Hi Aileen Thanx Alexandre from France
alexfr79
Sorry but it doesn't work
regards
Sorry but it doesn't work regards Alexandre from France
alexfr79
Please check pagination_list_render_common.php (attachments)
regards
Please check pagination_list_render_common.php (attachments) regards Alexandre from France
ajkosan
ajkosan posted this 25 August 2015
It also doesn't work for me after upgrade :(
still waiting for your solution. In pagination_list_render_common.php you can see that link target is #
Vito
It also doesn't work for me after upgrade :( still waiting for your solution. In pagination_list_render_common.php you can see that link target is # regards, Vito
thiago7
thiago7 posted this 26 August 2015
I'm waiting too! I have upgraded Themler and the problem persists.
I have to finish this project on friday and this pagination issue is driving me crazy.
Please, resolve this as soon as possible!
Thiago
I'm waiting too! I have upgraded Themler and the problem persists. I have to finish this project on friday and this pagination issue is driving me crazy. Please, resolve this as soon as possible! regards, Thiago
ajkosan
ajkosan posted this 26 August 2015
I have deadline on Saturday :)))
Pretty please :)
Best regards,
Vito
> **I have to finish this project on friday and this pagination issue is driving me crazy.** I have deadline on Saturday :))) > Please, resolve this as soon as possible! Pretty please :) Best regards, Vito
thiago7
I couldn't wait... and I found a solution.
Just opened the "protostar" template pagination file (templates>protostar>html>pagination.php), copied all its content and pasted it over Themler pagination 'engine' (themlertemplate>html>pagination.php).
You will loose the CSS styles, but you can't rewrite it using the "Custom CSS" field on "Settings" area and use the class ".pagination" for Joomla core content and ".k2Pagination" for k2.
It's not the ideal, but it works!
I couldn't wait... and I found a solution. Just opened the "protostar" template pagination file (templates>protostar>html>pagination.php), copied all its content and pasted it over Themler pagination 'engine' (themlertemplate>html>pagination.php). You will loose the CSS styles, but you can't rewrite it using the "Custom CSS" field on "Settings" area and use the class ".pagination" for Joomla core content and ".k2Pagination" for k2. It's not the ideal, but it works! ;)
Support Team posted this 27 August 2015
Hi guys,
I've asked our developers about fix with pagination.
Maybe this fix planned for next MAJOR update (Hot Fix is a minor update).
Hi guys, Sorry for the delay. I've asked our developers about fix with pagination. Maybe this fix planned for next MAJOR update (Hot Fix is a minor update). Thank you, Olivia
alexfr79
alexfr79 posted this 27 August 2015
Hi Olivia
I am waiting for 2 weeks. I think you have to fix this issue by now.
I gave you the way to resolve this.
I can't work with themler
Please fix this in online and desktop versions ASAP.
Hi Olivia I am waiting for 2 weeks. I think you have to fix this issue by now. I gave you the way to resolve this. I can't work with themler Please fix this in online and desktop versions ASAP. Regards Alexandre from France
